Keyboard types backwards in internet how to cure?
Discussion in 'Computers and Consoles' started by A.N. Other, Dec 3, 2007.
    Ive gone and done something with the control key no doubt how to I reverse it?
    Typing backwards is frying my brain.
    (wrote this in Word and pasted it in, btw)
    Cheers,
    Chris
  2. andypaterson Forum Member
    Cardiff
    typing backwards?
    do you mean that ^ would come out like:
    ?sdrawkcab gnipyt
    Yep!
    Turned the thing on and off and it went away, but I've done it to myself a few times now and am sick of having to turn the computer off/on to fix it.
    Hopefully someone has the answer!
  4. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Never seen that before!
    Sorry cant help this time Chris![:$]
    Will have a look tonight for you:)
    Cheers - would be good to know!
  6. andypaterson Forum Member
    Cardiff
    Maybe the 'home' button is stuck down or something, so that whenever you type a letter the cursor goes to the beginning of the line, making everything backwards. thats all i can suggest other than a virus!
  7. Breeny New Member
    Na, it's not virus/malware related.
    It's happenning to a lot of same brand laptops (Lenovo T60/X60)
    Oh.. by the way.. hello Chris! :)
    Hi Breeny - cheers for your help earlier :)
  9. rubjonny
    hmm, to narrow the issue I'd try to find a USB keyboard, if it stops doing it then I'd say the laptop or keyboard is to blame (assuming it is a lappy?)
  10. TIM
    Tim Forum Addict
    done some digging on google:
    could use this to help you?
    http://www.writebackwards.com/
    would correct your typing! lol
    tim
  11. dan0964 Forum Member
    Falmouth, Cornwall
    In IE, View - encoding - left to right
    any help ?
    Cheers for that Dan - I couldn't quite find "left to right" on the menu in IE, but at least know where to look now.
    There must be some shortcut I've hit to make it happen... [:s]
  13. dan0964 Forum Member
    Falmouth, Cornwall
    If you are using internet explorer 7 you need to press "alt" on the key board to bring up the menu, then go to view then encoding then left - to - right document, dont know if that helps at all.
    cheers
  14. dan0964 Forum Member
    Falmouth, Cornwall
