DIY Tubular T3 Manifold, Top Mount Turbo (PIC HEAVY!) NOW RUNNING
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by sambo, Feb 12, 2011.
  1. sambo Paid Member Paid Member
    Ok been a long while since i planed to start making this so here it is
    It may be usefull help to folks who also wants to give it a go and make their own manifold
    So step one will be buying or having made all the flanges you will need for your application as well as mandrell bent fittings
    For flanges i am using 10mm thick stainless steel laser cut for precise fit 316 grade
    Fittings are 1.5" Sh40 so quite thick side wall and perfect I.D. of around 41mm which matches my ports perfectly
    Flanges came from Ebay apart from main Cylinder head flange which i got from Andy Waite (Ak Bodycraft) white mk1 4wd owner, as he had one spare
    All bends came from firm in Blackburn called Eurostainless
    So i started with making a collector first, with a little help from my mate who is a fabricator and has band saw which helps with cutting stainless tube
    Sorry no pics taken during making of collector but you get the idea
    With engine in place its wise to check carefully where abouts you want the turbo to sit as its critical for making sure everything will have space to run like downpipe, wastegate, screemer pipe etc
    Once you happy with placement of turbo its time to fix collector temporarily where it will need to be so pipes can be made, as in pics above
    Next step is playing about with fittings to create individual runners
    You will need to be carefull here to make sure there will be no clashing and that you can get to all joints for welding
    For today i got as far as placing and temp fixing collector where it needs to be and making runner number 1, TBC tomorrow:)
  2. skoda4x4 Forum Member
    Looking good so far sam, ill be following this with interest !
  3. sambo Paid Member Paid Member
    :thumbup::)
  4. benny Forum Member
    Nice one Sam! Thanks for putting this up :thumbup:
    I was just on the Eurostainless website the other night ;)
    Keep us updated dude!
  5. m1keh Forum Member
    How do costs for all the pipes and flanges add up compared to buying a built mani?
  6. sambo Paid Member Paid Member
    I'v spent circa 170ish i think so it will work out hell of alot cheaper and this way i can make it custom fit. Will consider having it ceramic coated once its all made and tested/proven to work and perfect fit
  7. Trev16v
    Oxfordshireland
    I've just invested in a TIG machine with the intention of building a manifold, so I'm grateful for this thread and will follow with great interest.
  8. m1keh Forum Member
    Definitely worth diying if you can then :thumbup:
  9. alexisblades99 Forum Member
    sunny helsinki
    Thanks for putting this up Sambo. Do those pipe sections come pre-chamfered for good welding penetration, or did you have to do it yourself?
  10. Toyotec
    Those pipes are 'butt' weld ends and come like that.
  11. Toyotec
    Great work Sam.
  12. 1.8T_mk2
    1.8T_mk2 Paid Member Paid Member
    Hertfordshire
    Good stuff, looking good so far! :thumbup:
    What make / model did you go for?
  13. sambo Paid Member Paid Member
    Thanks for great coments lads, good to know few will benefit from the thread
    So today was a good day i am pleased with the outcome [:D]
    Gota bad case of weld burnt face tho but its not the first time, and cheaper then sunbed i guess lol
    On with pics and tips now. Tools wise today me n Bob have used
    Angle grinder with 1mm cutting discs, Inox (Stainless steel) one and grinding disc
    Air Die grinder with Carbide Steel rotary Burr bit for deburring after cutting tube
    Grips (Pliers) for holding fittings together during tack welding
    Mig welder with stainless wire, obviously Tig would of been better but hey Mig did the job
    Started with making runner number 4
    On with runner number 3, here i needed to extend couple of 90deg bends so vice and thin cutting disc came in handy, steady hand required!
    Then on with runner number 2
    Trying the turbo on making sure it is still where i want it to be
    Trying how downpipe will look like
    There you go, all in one piece now, removed from spare head and will be trial fitted to engine in place to tripple check all clearances are still good and to decide on final placement of Tail gate and route downpipe and screemer pipe will take
    then off again for Tig welding and blasting/cleaning before final fittment
    As it looks away from head
  14. sambo Paid Member Paid Member
    Just to add word of warning, use a guard on your angle grinder, dont be Ding bat like me as today i nearly ended up with ruined gentlemens area as the disc broke and shrapnel was everywhere!
  15. jettadan Forum Member
    Lancaster
    Thought you didn't bother with all that H&S namby pamby rubbish Sam......;):lol:
  16. benny Forum Member
    Looks crackin' does that mate! You make it look easy :thumbup:
  17. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Good work. Is it going to be TIG'd or MIG'd to finish it off?
  18. badger5
    nr Glos
    you know this, but I will say it anyhows just in case,
    If TIGing, you will be back purging it yea? and also, the head flange, must be bolted to a flat strong surface to keep it flat as it will want to distort like a mofo otherwise.
    head flange looks familiar.. Its one of mine :p
  19. sambo Paid Member Paid Member
    Deffo Tig-ed as i need welds to fully penetrate thick tube walls for max strength, dont think Mig is man enough and Tig is alot tidier
  20. sambo Paid Member Paid Member
    Yep Bill flange came from you i beleive, if and when you getting a batch going again i will be deffo having few if you dont mind, this one is first class
    And yes i am aware of warping issues thats why i will have flange end welds done last whilst bolted to the head as much as possible and whole lot will be back purged
    Runners one and four can be welded nearly fully in place as they are
    Runners two and three will be welded in place as much as possible to make sure they dont distort as they will have to be removed for welding hard to get to places near runners one and four
    Then put back on for final welding of all remainig sections
    I was led to believe when welding stainless manifolds its very important to take your time and do it bit by bit to allow cooling, it certantly cant be rushed or it will be well twisted!
