2 litre 8v probs
Discussion in 'Engines' started by momo, Mar 7, 2004.
  1. momo New Member
    Ive finally got my engine running, with 3a crank and rods, piper 285 cam, 35mm exhuast valves,3a throttle body and 16v metering unit. Im having problems setting it up, the c.o was very low-between 0.08-0.15, instead of between 1-2.
    Does the k-jet metering unit having a c.o adjuster screw?
    The haynes manual seems to think so, but mine doesn't
    Would the engine benefit from 16v fuel pressure regulator? How can i increase the fueling??
    cheers
  2. Rahul Forum Junkie
    16v fuel distribution and 16v injectors.
    Try this.
  3. momo New Member
    Its already got them, new injectors aswell. Did you have any problems setting your engine up?
