What Is Involed In Puttind A 16v Head On A 8v 2e Engine
Discussion in 'Engines' started by ianmorgan50, Dec 31, 2007.
  1. ianmorgan50 New Member
    south
  2. craggsy Forum Member
    Leicester
    If you want cheap easy 16v power then just drop the whole ABF engine in
  3. ianmorgan50 New Member
    south
    what will i need to do that or will it go stright in
  4. andy198712 Forum Member
    how can people reckomend this, i asked about this months back and got slated, for why make a car you can buy....
    i still wanna do it though ;)
  5. Spacemonkey Forum Member
    The grim north. And proud of i
    Do it.
    If you like the car and dont want to sell it, do what you want.
    Its your car.
  6. mk2_pete Forum Member
    i dropped an abf into my mk2 it goes like hell now well worth it i looked at putting the kr head onto my 2e block and decided there was no real point for the amount of work involved took me around 4 n half hours to have the abf in and running
  7. nealey Forum Junkie
    You cant buy a mk2 with a 2.0 16v in it though!! :lol:
  8. ianmorgan50 New Member
    south
    i could buy a 2.0 16v but i have spent a lot of money on this one and it seems point luss to sell it as that wound mean stripping it out and starting again with the new 1 i think it would be quicker to just change the engine
    so what is involed in changing it to a 16v lump what do i need a part from the engine to make it work
  9. drunkenalan Paid Member Paid Member
    Leicester
    the head will bolt on no probs, and no problems fitting it to the car, its after that the fun begins!
  10. rubjonny
    if you want to turbo it a 16v head on an 8v block is a good start as you get a nice compression ratio for boost. A 2e block is also good for boost as it has nice strong rods and piston squirters.
    To make it work n/a you need to change the pistons for 16v ones, as well as all the bits cerips spoke of. Hardest part of doing this either way is getting the crank timing sproket off, the bolt is done up to uber-torque!
    If you're going n/a, tbh forget it and drop in an ABF and run it with the ABF managment, much easier. There is even a sticky topic on the subject by Toyotec ;)
  11. Mike_H Forum Addict
    Why do you need to take the crank sprocket off to change the pistons - won't they just drop out through the sump if you undo the big ends?
  12. rubjonny
    you take the crank sproket off becasue the 16v timing belt is different to the 8v one, you gotta fit a 16v timing belt spoket :)
  13. Mike_H Forum Addict
    Ah - good point well made!
  14. rubjonny
    well if I'd said it properly the first time it woulda been better :lol:
  15. andy198712 Forum Member
    i was thinking more a VR lump but yes, yes mate you are right!:clap:
    before some one says it, you cant buy a VR anni:lol:
