Club GTI
4th October 08, 11:36
#1
Forum User
mk1 caddy 24v turbo 4wd project ,stress...56k warning
hi all i know this is gunna be stress but id thought id share ,as i may need some advise on this buggar,as ive facied a caddy for a while and always liked the mk1 golf caddy shape ,it was only when i went and called in at a local farm and found a mk1 caddy been used with a forlk life for a gate post,,coverd in nice green mold,so after chatting with the farmer i bought it ,as its in a poorly state at mo due to been stood for 7 years ekkk:(,so i eveturly got it home ,with nice brakes burnt out ,and sized wheels ,,
plenty of holes and rot too,along with holly floors too
so after a 2hour wash ,i can see potentioal
and that horried back is going plus the old 1.6 diesal and gearbox is too
so next thing i thought i need a power house ,and thought id do some modifaction to get a nice mk3 vr6 in it ,
yes i know these dont fit by just bolting in more mods are needed ,
then thought it will make the front end heavy so thought ill buy a complete 2001 mk4 golf 4 motion rear axle for some extra grip
asi was only going to make it 2wd drive ,i thought id better make it 4wd so bought a nice 02m 6speed gearbox to fit to my 12v vr6 lump
then sorted a proshaft and some spare drives etc
then thought these engines are only 174ish bhp ,erm and id had the ecu chipped to 200bhp i still wasnt happy ...so i thought id buy a transfor box and turbo kit etc for my set up
4th October 08, 11:42
#2
Paid Member
This is gonna be a hot one baby! Looking forward to seeing more
__________________
Beware The Sleeper
1.8 20vT Mk1 5 Door GL
4th October 08, 12:03
#3
Forum User
then fitted my gearbox starter ,part turbo kit and 4wd transfor kit to the engine
,thought id basicly get all the runing gear sorted saves hunting around at a later stage ,then i hit a small prob ,the rear golf axle is not only too wide but the ecu is called haldex and needs a controller to work ,this part from dealers called haldex ecu is 600..that just for this little box
and beteen 600 to 850 for a part to control the 50/50/50/100 all time 4wd system,so i thought chuff that ill make my own,after a bit of stress ive sorted the curcit ,stepper,and controller to make it work nice ,for either raceing or daily driveing,,
then dropped on some mk3 coil overs which im hopeing i can use mk1 top mounts,then shortern drives ,a arms quick pic here
just built the meqa squirt ecu up and cranked the engine and put a map on the ecu so it should run in theory lol,,,
and thats as far as ive got within 2 weeks im affraid but there will be plenty of burning welding filling .modifying to come,,,,
4th October 08, 12:12
#4
Forum User
oh i dint know mk4 r32 drives bolt sraight up in mk3 hubs saved a little job
and slightly skimmed the inner alloys to dish ,so they nicely miss the rear calipars and rear dampers
all fits well
and some alloys ther will have to do with a quick refurb at a later stage
4th October 08, 12:21
#5
Forum User
i thought id make a manifold for the caddy vr6 and heres how i did it ,,3hours all done ,im just unsure which way the thottle body is supose to be,,
bit of drawing first
then a bit of drilling
bit of grinding
welded bolts in place
cut some tube and welded some steel
end plate for thottle body
quick grind around
grind ed it up
job about done ,just a couple of pipes and thottle hanger
i hope theres enoegh pics for u ...
unsure how close it will be to the front ,as i just gessed,,,
lol its usely the case small things take longer then the buigger jobs
well,lol if u think were poeple use fit the turbos on the vr6 ,the turbo,downpipe,manifold get really hot ,and the intake is bang above,so its like a big heat sink along with under bonett and hot compresed air ,so u make one of these thow it on, and it thows direct air into the engine, and takeways all that hot ait and heatsink,so u get a better turbo pull and low induction temps,
colder the air better the power gain ,hotter the air more the engine lacks and runs crapy,,,
right this afternoon i had to go and see if it would fit bolt up and weld servo and fuel reg pipes on fit and looks ok for a first attempt
evern pipes fit o too
then thought we might as well that manifold will be hot so make a quick cover for it ,a bit of bling or somert like that
fits ok ,
be nice when im ready to mod the turbo too,,,may look a bit more like a engine lol
little update not too mutch as im still filling the bug ,but i had a few hours spares so i noticed this pipe and im sure this is why i had a water problem ,
anyway i went and bought a r32 golf thermostat houseing so i cann select 5th and 6 gear due to the std vr6 themostat was in the way
these are the too houseings
then made some bolts
nice fit in the r32 houseing
notice the std vr6 and the r32 tube lengths
so houseing pipeing fitted and std vr6 sensors fit in the houseing too
decided i dinr want power steering so removed all that along with the aircon bracket ,so i can add somert at a later stadge to the engine
belt pulleys sorted
decided to use differnert type of ht leads
and polished rocker as well tidys things a little
4th October 08, 12:25
#6
Forum User
Quote:
unsure bud never drove one of these buggars ,,but one we will find out i reckon, i dont think the scoobys fans will be too inpressed ,when i pass then like there doing 40 lmao...
4th October 08, 12:27
#7
Forum User
some engine problems,got the engine runing on the floor,and 10mins of runing ,a horrible noise came on ,so its bloody strip down again ,stress,mind im glad it wasnt all fitted and this happernd on a test run..
problem a little end on one piston and i need some more piston skimming too,,for more boost.and timing chain guid smashed
so made the flywheel fixed ,to make sure it will hold bhp
aint done ought to the bug ,as i didnt want the engine full of dust,
started building engine engine back up 2day ,as i thought chuff the head spacers ,get the lathe out and skim em lol
more engine build ,,,carnt wait to start the dam caddy lol
therd some bolts and bit of welding for the flange
4th October 08, 13:09
#8
Paid Member
looks like an awesome project,
had thought of doing this when i had a caddy, but i have no skills in fabbing such stuff up!
good luck with it!
__________________
Quote:
Originally Posted by Gaz37
Quote:
Originally Posted by PeeJay
No probs, expect a PM Sunday morning. I take it usual 'bread on the head' rules apply?
No your mrs holding a sign saying "I wish this was you Gaz" would suffice
#9
Forum Junkie
wow mate good skills, look forward to seeing this come together.
__________________
4th October 08, 14:11
#10
Forum Junkie
so awesome man!!!!!! keep it up
4th October 08, 16:03
#11
Paid Member
cracking stuff, keep the updates coming
4th October 08, 19:56
#12
Forum User
bit more modifying done this after
had to make a head spacer needed the compression lower ,,
then its start chopping the rear axle to size
rewelded it up in place
then got a bit ampage on the go ,,i dont want these snapping off
axle shorternd
next antiroll bar needs shorterning so instead of choping welding ,i decided to heat and bend it
sorted
double checked measurement
just a mock up with the caddy tailgate ,and it should fit,,
not mutch to add due a nice hangover from the night before lol ,so just tacked the short runner pipes up
made a return pipe ,had to weld it in 5 places to get it right
right after trying 7 differnert headgaskets i finaly got a steel one to fit lol ,so carried on with the homemade headspacer ,chuff buying when u can make one
so carried on with may home head spacer lol
once the runing gear is sorted ,its caddy modifying time
a small change in plans lol ,im not going to use a old mk3 vr6 turbo ,that ill go on ebay ,ive decided to try attempt fit a later mk4 4motion 24valve engine and turbo that instead ,so started again as im more happy with this idea so heres what i bought,as i couldnt leave it right bargin..
head off all valves re seated and skimmed
ill be makeing another turbo manifold,inlet manifold,etc
starterd on the manifold 2night had to do somert
think it may work..
injectors arrived 2day
erm lots of fuel useage lol
thats the manifold turbo about sorted,
next time to start and make another dam inlet manifold,,,lol
once thats something like useable i want to get the buggar runing on the floor make sure we have boost lmao
COUPLE OF MODS THIS AFTER sorted oil feed and couple up,remove old cam sensors ,ill not need them made a plate ,
fitted coil pack
next i need to get the ecu sorted and wireing
IM CHUFFED HOW TURBO IS SAT ,NOT TOO HIGH so bonnet should shut in theroy lol
JUST BOUGHT MY STANDALONE ECU AND WIREING HARNESS ANOTHER BARGIN.....
modifyed some nice decent size cc injectors ,
intake manifold to make next ...
and a few tuning bits arrived too,,
also added lunch control for tracks and a stand alone rev counter ,,
4th October 08, 21:19
#13
Paid Member
Bonkers !!
I like it a lot !
4th October 08, 21:49
#14
Paid Member
Pure mental, I salute you! Cant wait to see it finished, are you leaving the bodywork as it is?
__________________
4th October 08, 22:16
#15
Forum User
Quote:
cheers guys ,yep ill sort the welding etc ,but ill leave it rough ,just a quick home made idea ,as it will end up were it started ,  ,may get a little more done 2moz wheather permiting ....
4th October 08, 22:38
#16
Administrator
This is looking like a pile of Scooby trouble indeed!
Some great fabbin skills - just promise us you'll finish it. Nothing's got in your way so far
5th October 08, 09:41
#17
Club GTI Sponsor and Supporter
great read.
looking fwd to next installment
__________________
BADGER 5 LTD: PERFORMANCE TUNING
RACE PROVEN PRODUCTS & HONEST ADVICE:
Contact:07976 800775 or 01453 827936 Fax-0870 0561360
Bespoke Big Turbo conversions,Forge,Ferodo,AP,Custom Code,REVO,H&R,Eibach,Vibratechnik,SPEC,Compmotive, DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more...
http://www.badger-5.com
email me at: bill@badger5.co.uk
5th October 08, 11:30
#18
Paid Member
very nice work mate, its gona be a right stealth flyer.
Jason.
__________________
THE RAMPANT ROCCO
Scirocco gtII, AUM 1.8 20vT
5th October 08, 16:08
#19
Forum User
Is that head spacer part of the Disney club?
5th October 08, 16:21
#20
CGTI Regional Host
lol! nuts
check out the 3.2 sump thread i started on vr6oc if you're having clearance issues.
__________________
TEAM GULF
5th October 08, 20:33
#21
Forum User
bit of work started on the caddy this after rip the rear hood off ,ripped the oil 1.6 oil burner and box out exahust off ,gearlinkage out
pedal box out,found a few more rottern parts eg rear floor,rear roof,bits on inner wings ,
few mock up pics of were ill roughly fit it
as u can see fitting this isnt going to be hard at all ,
bit of cutting choping here and there and that bit ill be mounted ,
then ill mod the power steering as well,
rip the tunnel out ,fit another ,algine prop ,and adapt tthe rear axle ,,
everthing ive thought off so far isnt no were near as bad as first thought,
bit more done on the mk4 turbo lump too,,,
oil return sorted and a start on the inlet manifold this afternoon
home made oil pipe,every little bit comes in
removed sumps as the early steel one fits and is cheeper to replace if i hit a hump lol
engine comeing along nicely now ,,,
soon be ,,caddy moding time ...carnt wait ,,,lol like a kid in a sweet shop
5th October 08, 21:12
#22
Forum Junkie
I think this is the fastest project CGTi has ever seen  cant wait to see the rest of it coming together
__________________
5th October 08, 21:57
#23
Forum User
Quote:
nice thought but i woundnt go that far ,theres some real quick v dubs on around,,,have to say though ,at some point im going to have real tracksion problems over 400bhp lol ,ive evern got my fuel maps set up enough fuel to run 560bhp ,,,just fitted a sweet 4bar map sensor too ,probley never use it ,but i supose its there if needed ,,,,cool reply ,,,
5th October 08, 22:05
#24
CGTI Regional Host
What a project and well done!
There are some serious projects going on atm!
6th October 08, 00:35
#25
Forum Junkie
lol i actually ment the fastest progressing, but it will also be one of the faster dubs about aswell!
__________________
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
