Forums Member Login     Join Online Contact
Go Back   Club GTI > Gallery > Members Gallery
Brentacre Advert
Reply
Thread Tools
Old 15th September 09, 13:27   #26
jettadan
CGTI Regional Host
Quote:
Originally Posted by Chris Eyre
[My two-penneth on the Mintexes is they're fine. I used to run 1144s. EBCs simply just have higher market profile these days, and I've run those too (greens and yellows).
Chris - what was the difference in the Greens and Yellows? I've got the greens fitted at present but interested to know how they compare to the Yellows.
Oh, and good progress on the Rocco Mike
__________________
jettadan is offline   Reply With Quote
Old 15th September 09, 13:30   #27
Chris Eyre
Administrator
Chris Eyre's Avatar
The yellows are a bit more aggressive (reds are in the middle). Bit squeaky, and they're a disc metal grinder no question, but great for upping standard brakes to instant hard trackday durability.
__________________
________________
Track car | Field car | VWMotorsport.info | SeatSport.info
Forum search tips here. If you have a general question about your car, please don't PM - post a thread, so that others can benefit too.
Chris Eyre is offline   Reply With Quote
Old 15th September 09, 23:55   #28
RogerM
Newbie
Interesting with the Mintex, seems to be a marmite pad!!!
My experience of them (all on Minis not VWs I have to say) is very bad but I know others that swear by them.
My experiences have been
pads breaking up in less than 500 miles
mismatched pads in a box
aweful feel from cold (not really a problem for a track car but lethal on the road)
and hugely noisey.
The only negative I can give for EBC from my own experiences are that the life is quite poor. Again for a trackday car that isn't much of an issue.
For the road I use Ferrodo pads where there is a suitable compound available, EBC otherwise.
Like many things with car tuning, horses for courses!!!
__________________
89 GTi cab
85 Scirocco GTX (soon to be 18T and Rieger GTB)
98 Passat Estate TDi
04 Ibiza
RogerM is offline   Reply With Quote
Old 16th September 09, 07:24   #29
Mike_H
Moderator
Mike_H's Avatar
Quote:
Originally Posted by RogerM
Enjoying this thread and please keep the updates coming!
2 questions though ...
1) what oil filter are you now running?
2) Why are you changing from EBC greens to Mintex 1144? I wouldn't run a Mintex pad if my life depended on it .... had nothing but problems with them and my pad of choice for the road / occasional track use being the EBC green! Very curious why you have gone in the opposite direction.
1999 Polo 1400 8v Filter. I'll post a pic. It also has a handy 30mm nut on the end, for easy removal.
I know people whose EBC Greens have fallen apart on trackdays (friction material fell off of backplate), due to heat. The ones on there are also squealing like mad. Most of the serious rally types I know wouldn't touch EBC Greens. Mintexes are fine if you bed them in properly.
__________________
If you have a question about what's wrong with your car, please don't PM me. Post your question on the forum, so that others can read it too.
Nordschleife video: http://www.youtube.com/watch?v=p8bTRVzL1TI
Track Car Development Thread: http://clubgti.com/forum/showthread.php?t=188575&page=2
Mike_H is offline   Reply With Quote
Old 16th September 09, 07:27   #30
Mike_H
Moderator
Mike_H's Avatar
Quote:
Originally Posted by Mike_H
Also started fitting the oil cooler (which is what the short oil filter is for). I'm leaving the oil/water cooler on there, and adding the 13 row cooler - which is actually the same one the engine ran with when it was in Claire Tippet's (now Chris Eyre's) VW Cup Mk1. Engine and oil cooler re-united. I love a happy ending!
Good to see the cooler going in!
It ran without the water-oil cooler when I had it, so that must have been a retro fit by Mr Brown or the subsequent owner.
When I bought the car it wasn't running an oil cooler at all. The water/oil one was fitted by me, along with replumbing the cooling system. Also, the way the cooling system was fitted by the previous owner (one water pump outlet blocked off), the water didn't circulate unless you had the heater full on. Not good!
__________________
Old 16th September 09, 07:39   #31
Mike_H
Moderator
Mike_H's Avatar
Oil cooler is now mounted
Shorter filter
Cooler is mounted on 'cotton reel' type exhaust rubbers - I wanted to protect it a bit from vibration.
Lots of room now, where the battery used to be. Used a simple junction box to join the live wires. I've set this up so, if I need to, I can pull it all apart, and refit another battery in about 10 minutes.
__________________
Old 16th September 09, 09:50   #32
Mike_H
Moderator
Mike_H's Avatar
It's on, oil filled into engine, leak test done, run up to temperature (see the high tech test materials).
The 'Ring grille is back on, for added scene points
Just a 'few' more jobs to do tonight, before it's ready for the 'Ring trip.
__________________
Old 17th September 09, 13:31   #33
Mike_H
Moderator
Mike_H's Avatar
Last update.... last night I put a proper thermostat back in, as oil temps were struggling to get to 80 degrees C with the chopped one, jacked up the back suspension (so I don't drag the exhaust off on the Ferry) and re-hung the exhaust. Then I packed the car so I'm just about ready to go.
This morning I had some of the R888 tyres swapped around and rebalanced, so I've got the best ones in the right places. Filled up with petrol at lunchtime, and Just have the clothes bag and helmet bag left to go in. With a bit of luck, I might even give the car a quick wash before I go.
__________________
Old 17th September 09, 16:24   #34
Matt G
Forum Junkie
+35 bhp
__________________
smoke me a kipper, i'll be back for breakfast.
Matt G is offline   Reply With Quote
Old 17th September 09, 18:25   #35
steve r
Paid Member
steve r's Avatar
Good work Mike, coming along nicely
__________________
Please click the logo to find out more including how to register as a donor.
steve r is offline   Reply With Quote
Old 24th September 09, 12:56   #36
Mike_H
Moderator
Mike_H's Avatar
Post 'Ring report is as follows:
The car went well - only problems I had were a self-adjusting tickover, a sticky clutch cable (heat related I think), and the oil is still getting a bit hot. Best time I did was 9:26 on a drying track. Next jobs are:
- Sort out the tickover screw (there's a big plug of blue hermetite over it at the minute)
- Move the oil cooler so it gets more airflow (or cut holes in the bumper)
- change the rocker cover for a less rusty one
- a bit more fiddling with the home made throttle linkage.
- lighten the bumpers a bit (maybe just the front, as the rear of the car is V light already.
Then we're onto the major winter jobs:
- Megasquirt conversion
- Plastic Windows
- Fit Direct brake master cylinder & delete servo/linkage
- Rollcage
- Top Mounts (maybe)
- Change gearbox, and add lightened flywheel/comp clutch.
More updates soon...
__________________
Old 24th September 09, 14:56   #37
jettadan
CGTI Regional Host
What gearbox plans you got?
I know of a close ratio 020 with a Quaife diff and Sachs clutch that will probably be coming up for sale towards the end of the year.....
__________________
Old 24th September 09, 20:21   #38
smudge
Paid Member
Liking this project, looking forward to seeing the winter plans put into place. If you want any MS help i live fairly close.
__________________
Want Free Porn? Visit the ITB porn thread here.
smudge is offline   Reply With Quote
Old 25th September 09, 15:50   #39
Mike_H
Moderator
Mike_H's Avatar
Plan A is a rebuilt 2Y on standard diff and ratios.
Plan Q sounds interesting though, depending on price, and more info. Do you know what diff ratio it is, and what the original 'box code is?
__________________
Old 25th September 09, 15:51   #40
Mike_H
Moderator
Mike_H's Avatar
Quote:
I may yet take you up on that. I'd still like to have a look at your one (eventually!)
__________________
Old 25th September 09, 17:32   #41
16vChris
Newbie
Saw you at the 'ring, shame I never got a chance for a chat I was in this
I've also got plans for a gearbox change after my trip, so will be interested to see how you get on. Added lightness is always a bonus too.
16vChris is offline   Reply With Quote
Old 25th September 09, 23:21   #42
shaz8389
Forum Junkie
shaz8389's Avatar
Looking good Mike, think I need another look at this motor soon, I remember coming over when you were taking the sunroof out and going on your mad weight reduction mission.
shaz8389 is offline   Reply With Quote
Old 28th September 09, 21:36   #43
Mike_H
Moderator
Mike_H's Avatar
I remember seeing the plate. Hope you had a good trip. What's the spec of the car?
__________________
Old 28th September 09, 21:37   #44
Mike_H
Moderator
Mike_H's Avatar
These arrived today... from Compbrake. Sorry about the pic - the iPhone doesn't like low light.
__________________
Old 28th September 09, 21:43   #45
gillm
Moderator & Regiona* Host
gillm's Avatar
i have them and they are nasty on the road .
__________________
mk5 gti revo stage 2
mk1 9a track toy
mk2 vr6
gillm is offline   Reply With Quote
Old 28th September 09, 23:38   #46
jettadan
CGTI Regional Host
I've got them (old TAS ones) and don't find it too bad tbh - obviously not as forgiving as original ones, but the improvement in handling is worth the sacrifice
__________________
Old 29th September 09, 12:31   #47
Chris Eyre
Administrator
Chris Eyre's Avatar
They're fine! When fitting them, watch the castor, as it weights the steering up quite a lot.
Good to see this coming along.
__________________
________________
Old 29th September 09, 18:04   #48
Mike_H
Moderator
Mike_H's Avatar
I'll get down the gym then, or take some more weight off the front of the car - or both! I guess that's partly why the 911 steering weights up in corners - I think it runs a lot more castor to make it turn in.
__________________
Old 29th September 09, 20:13   #49
jettadan
CGTI Regional Host
How have you got your's set up Chris? I tried to set mine up with more caster and camber by having them towards the rear and middle of the car if that makes sense!
__________________
Old 29th September 09, 22:43   #50
Chris Eyre
Administrator
Chris Eyre's Avatar
It's as it came - rear and middle.
Without power steering it was fairly heavy and self-enter orientated. I think the diff is contributing, but unless you're happy to bully a car, steering-wise, it personally think it would be useful to have an option to adjust back more towards OE settings in case a get out is needed.
__________________
________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
