VR6T Rallye rebuild
Discussion in 'Members Gallery' started by VR6T, Apr 17, 2009.
  1. VR6T
    VR6T Forum Member
    Aberdeenshire
    Well after it sitting in the garage for nearly 4 years, I push it out side today and started to strip it ready to go to the body shop.
    First up i had a look at the sills.
    After a good poke with a screw driver
    This is the worst side.
    Next i had already removed the screen over a year ago, so i cleaned off the bonding to have a better look at the damage.
    Its not looking to good and VAG have made the scuttle panel obsolete[:^(] so if any body has one going spare I would be interested in it.
    Next I took out the rear side windows and i still can't believe VAG mounted those stupid clips to hold the trim panel. Both side have rusted away.
    So all i need to do now is remove the dash and the remaining carpet and its off to the body shop
  2. RIP-MK3 Forum Addict
    sunbury on thames
    will be awesome...... if you didn't have soooo many cars it might have happened sooner :lol:
  3. VR6T
    VR6T Forum Member
    Aberdeenshire
    You sound like my wife...:lol:
    Is this reg plate G** WAS?
  5. coullstar Forum Member
    Scotland
    About time to. Rust doesnt look any worse than the last time I saw it. Worthwhile doing it, maybe just have to get rid of some of the others to get properly motivated. Still might be interested in the Passat as Im not off across the water now although there is a local Mk5 4motion Tdi that looks ok.
    Chris, it is.
  6. VR6T
    VR6T Forum Member
    Aberdeenshire
    Yes it is......
  7. VR6T
    VR6T Forum Member
    Aberdeenshire
    Just give me a shout ...
    Excellent - I remember the mag feature.
    Passat VR syncro bellhousing IIRC?
  9. VR6T
    VR6T Forum Member
    Aberdeenshire
    Oh yes the good old Six Pack feature
    Well the bell housing is actually one of two that a certain Mr Gemini took back from Hanover. It it a proper pre production sand casting item.
    The other housing went on the Silver VR rallye Jim Cotton built back in the day..
    Cracking info - special as they come :thumbup:
  11. Matt G Forum Member
    somewhere in the north east
    dunno if its any use but veedubs in gateshead have a rallye shell lying around (or at least did last time i was in a few months ago!)
  12. VR6T
    VR6T Forum Member
    Aberdeenshire
    Was it a RHD side one i have 2 LHD side ones
  13. Dan W
    Dan W CGTI Regional Host
    Penryn, Cornwall
    do all rallye's suffer this bad with corrosion? you'd think being so expensive new that they would be better built than a normal mk2, always thought one day i'd own one but if they rust this badly I might have to reconsider!
  14. PhatVR6 Forum Junkie
    yes, they are rot boxes.
  15. Blue MK2 Forum Member
    wiked project.
    Aalmost all mk2s have the problem with rust on the winscreen frame and the rear windows but rallyes have the extra sill problem.
    Its that horrible metal clip on the rear side windows that starts the rust off:lol:
    I dare you to acid dip the shell!
  16. Matt G Forum Member
    to be honest i have no idea, it was a while ago, i just looked accross and thought "damn"! :lol:
  17. VR6T
    VR6T Forum Member
    Aberdeenshire
    Productive morning, managed to get the dash and carpet out..
    How much of a pain is it to remove the clove box on a LHD MK2 had to loosen of the dash to get out, there was lots of bad langauge.....
    Its now ready to go [:D]
    The plastic bag contains the 2 mile of wiring and control modules for the cat 1 alarm.
    Couldn't believe the amount of stuff that was hidden behind the center consul..
  18. 12valver Forum Member
    Good to see some progress :thumbup: It must've been a fair effort emptying the contents of the car :lol:
    I've been waiting a few years for a passenger ride in this!!
  19. VR6T
    VR6T Forum Member
    Aberdeenshire
    It took a day and a half to do, never taken a MK2 apart before.
    The MK3 is a lot easier to work on ...
    There is a que ;)
  20. copeidge
    copeidge Forum Member
    truely amazing!!!
