how to replace the oil seal in a 16v distributor
Discussion in '16-valve' started by MUSHY 16V, May 1, 2009.
  1. MUSHY 16V
    aberdeen
    this is a guide how to replace the oil seal in the 16v distributor
    and is all so handy if you have to change the hall sender
    it has always amazed me how much a new or recon distributor is they start a about 80
    it is usually only the oil seal that wrong with them
    and the seal only cost 2.30
    hear are some of the things you will need
    * pin punch
    * hammer
    * scriber
    * feeler gauges
    * two sockets
    * Vaseline or oil
    first you need to remove spring clip round the distributor drive not all distributor have this
    then you need to punch the dowel pin out with a pin punch off the right size about 2.5mm
    you will need to line it up as below
    it all so pays to mark the shaft and distributor drive at this point
    now remove the drive and washers dress and rags on the hole thru the shaft
    and then gently drift the shaft out remove shaft and washers
    now using a scriber with tip bent with a short 90 degree bend like below
    remove the cap washer that is on top of the seal by putting the bent tip between washer and the seal then carefully tap it out
    now do the same with the seal you will have one side then the other to get the seal out
    evenly
    now you should be left with this
    now you clean all the parts and polish the shaft where the seal runs
    now you are ready to put the new seal in
    place the seal in the bore then tap it in evenly with a sockets just smaller than the bore
    tap it in till it is all the way home
    now you want to put cap washer back on line up the serrated edge with the old marks on the bore
    then tap it home with a sockets tap round the edge and not in the middle
    so not to distort the washer
    now place the two washers back on the shaft the fibre one then the shim
    then smear Vaseline or oil on the shaft
    make sure there are no rags on the hole of the shaft now push the shaft thru the seal
    put the washer back on
    then put the distributor drive and line up with the marks you made and line up with
    the slot in the body
    and punch the pin in
    make sure the pin is centred in the shaft then fit the spring using the feeler gauges
    to slide the spring other the slot
    you can now fit a new o ring the the body and fit the dust cover and rotor arm
    you are now finished and ready to refit the distributor if you marked it before you
    removed it you can just line it back up if not you need to re-time it
    the seal is 12x19x5 you can use single or double lip seals i used single lip
    distributor body o ring
    the o ring size is internal diameter is 37.5mm and the cross section is 3mm
    bs4418 0375-30
    http://www.allianceseals.co.uk/BS4518-Metric-O-Rings.php
    hear are some handy links
    http://vwdoc1.tripod.com/16VDistSealReplace.html
    http://www.gti16v.com/16vfaq.htm
    http://www.ffp.fi/index.php?mid=2&pid=115
    http://forums.vwvortex.com/zerothread?id=3536766
    http://simplybearings.co.uk/shop/
    MUSHY 15/01/10
    16v dizzy
  2. italian job Forum Member
    Mate,thats very helpful,cheers:thumbup:
  3. Nige
    Nige Paid Member Paid Member
    Great guide !
    Isn`t getting the camera to foxus closeup a pain sometimes !!
  4. GVK
    Excellent guide, nice one!
  5. Brookster
    M1 J40
    Good work :thumbup:
  6. MUSHY 16V
    aberdeen
    thanks guys
    the photos where a pain it was to dark and i used no flash
    may try and do some more at some point
    going to do a edit and add to it
    cheers mushy
  7. MUSHY 16V
    aberdeen
    cheers love your new engine makes me wish i never got rid of the mk1
  8. MUSHY 16V
    aberdeen
  9. rubjonny
    not my linky, i got it from the original how2 guide. all i did was copy/paste it with working pictures as original host went down :)
  10. mk1. Forum Junkie
  11. dragonfly
    dragonfly Paid Member Paid Member
    Birmingham
    Excellent guide!!
    Great guide. Just speaking to these guys - are they the place you ordered from?
    There's a min order charge. Anywhere they can be bought from individually?
  13. rupe Forum Member
    Great, thanks. Any idea of the diference between the two?
  15. rupe Forum Member
    Top man - this is an awesome fix.
  17. Mike_H Forum Addict
    Stickied.
  18. MUSHY 16V
    aberdeen
    cheer mike
    chris i got me seal from Eriks they are nation wide and have a branch in aberdeen
    they have no min order charge but i did have to get ten to get the price down
    http://www.eriks.co.uk/branchfinder/
    i think i still have two left if you need one
    i have all so made the fibre washer as well
    for my self and neil kaye
    from tufnol sheet
    Ah, I've got the inner seals now, two actually as I've got 2 to do.
    Where does the fibre washer come in? Can you pick up the relevant pic?
  20. MUSHY 16V
    aberdeen
    nine times out of you can reuse the fiber washer but they are eazy broken
