Guide on how to make carbon fibre/fiber car parts (ITB trumpets)
Discussion in 'Throttle bodies & non-OEM ECUs' started by Admin, Sep 7, 2009.
  1. Admin Guest
    Had a couple of questions about how i have made some carbon fibre bits and bobs on my car so i thought i would put up a little guide with pics showing you the basics.
    I have decided to use a carbon fibre trumpet to demonstrate, this is nice and small but shows how to create shape and moulds.
    Finished carbon trumpet
  2. vw_singh Events Team Paid Member
    Nice job!
    Where do you buy the carbon cloth from for a decent price?
    Gurds
  3. Admin Guest
    i bought it local but these guys are pretty cheap and will sell everything you need.
  4. James_mk2 Forum Member
    Farnham, Surrey
  5. Admin Guest
    Chopped strand mat is good stuff but only when used in correct places, it offers lots of stiffness and rigidity but it is heavy and quite thick. I only use this stuff to make the moulds from because of the above and it is cheap.
    I would use the woven mat for wings.
  6. Nige
    Nige Paid Member Paid Member
    Probably worth mentioning that you need some good rubber gloves when working with the weave as the resin gets everywhere !
    As usual, great guide !!
    The laquer makes a huge difference to the finished appearance, good idea.
  7. turbotommy Forum Member
    Newcastle upon tyne
    Fantastic guide!!! thanks for doing it.
    Can this be made a sticky as i'm sure alot of people would like to see this.
  8. steve G Forum Member
    great info :thumbup:
  9. 2dubnick Forum Junkie
    Worcester
    nice guide:clap:
  10. PhatVR6 Forum Junkie
    fantastic, i need some of that in my life
  11. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Done. :thumbup:
  12. Brian.G
    Brian.G Forum Member
    West of Ireland
    Its threads like these that make this forum a great place to be, WELL DONE, Im very impressed,
    Brian.
  13. thegave Forum Member
    London
    www.cfsnet.co.uk also sells fairly reasonable carbon fibre supplies inc resins.
    sweet guide
  14. shaz8389
    shaz8389 Forum Junkie
    A question about Carbon Fibre bonnets, I've seen loads of them that remain the same look but I'm wondering if they can be painted to match the body as I wouldn't like the look of it on the front of my car (think it looks tacky on some cars) so would want to match it to the rest of the car as if it was just metal but have the reduced weight benefits.
  15. James_mk2 Forum Member
    Farnham, Surrey
    They can be painted, in fact a fair few supercars (the more extreme ones) have carbon panels which are then painted.
    You can also paint it with a much thinner layer than you would usually so you can see the weave through the paint but without having the colour of the carbon fibre.
    Top work Tom :clap:
    Sticky/FAQ? If it needs moving, let us know :thumbup:
  17. Admin Guest
    Just to follow this up a little bit here is the finished set of ram pipes mounted to the ITB's.
    Hope you like.
  18. altern8 Forum Junkie
    Cocos (Keeling) Islands
    that is superb, did you make the backing plate too?
    could it be used to make door cards or speaker pods? how strong is it once made?
  19. Admin Guest
    The backing plate was made from 5 layers of carbon, it is about 1.5mm thick with good ridgity, you can easily make door cards (just need to work out how thick you would want it.) then lay it all up on a very flat and smooth surface - i use an of cut of kitchen work top as it is very smooth giving a great finish plus it takes little in the way of prep, just a smear of release agent and it popes of easily.
    Door cards are agin a thumbs up, you just need to first amke a good plug and then a mould, once the mould is made you can make as many as possiable.
    :thumbup:
  20. Nige
    Not bad I suppose... ;)
