Hiya fellas I've been trying to source an oil cooler kit for my 20vT, but there doesn't seem to be a "kit" available. see plenty for the 8v/16v/G60's, is there any difference between these and one that will fit a 20v?? Any recommendations much appreciated!
Talk to www.speedflowshop.co.uk or www.rallydesign.co.uk - they can supply all the components you need.
I asked rally design about a kit for my 20vt engine and they were about as usefull as a chocolate tea pot, just told me they didn't do one??. I will give the other guys a go though
Speed flow shop looks good. Mook - If I opted for this kit on here: http://www.speedflowshop.co.uk/engi...plate-with-stealth-black-hose-ends-1395-p.asp Do you know the sizings and options required to fit to a 20vt in a mk2? Also where have you placed your oil cooler? (As my intercooler stops me fitting a corrado vr6 rad I figure its an easier option to go for the oil cooler to run lower temps and gives me the sandwhich plate for some guage senders too.
That's exactly the set-up I bought off them. Call them to order it and they'll make sure you get all the right parts. If it's not a track car, you only need the 13 row cooler (I blank off the top third of the oil cooler when I'm not on track). Weirdly, the sandwich plate to oil filter adaptor threads you need are imperial - all VW group cars use imperial for the oil filter. Mount the oil cooler in front of the radiator & intercooler.
This looks a good piece of kit, think i'll go for one on my mk1. Is a 16row cooler overkill for a mostly road car with occasional track use?
Thanks Mook. I been measuring up for the kit the weekend and have realised that putting a sandwich plate in would give the oil filter near no ground clearnace! the way the enigine sits in the mk1 it's already just about tucked up beneath the front panel! Any mk1 20vt owners here running oil coolers??
What you shouldn't be doing is letting small technicalities get in the way. Remove the water/oil cooler/heater (sits above the filter) and replace the threaded pipe and you'll gain the clearance you need.
And these are the guys to get what you need from www.thinkauto.com - they're based in Twickenham - have everything on the shelf and they're helpful as well.
Do you really need an oil cooler on a 20vT? I have never seen my oil tempo (MFA) pass over 96, even in a trackday, in June last year.
HidRo - yes, you need an oil cooler on a 20vT, esp on trackdays. Jon - remove the oil/water cooler and you'll have an over-sized threaded tube for the filter to attach to. Chat to the guys at Think Automotive in Twickenham (they are Mocal) and they'll provide you with a shorter threaded tube and the necessary take off adaptor to go to the external oil cooler. You'll be left with two water pipes which would normally connect to the oil/water cooler - cut these at the other end where they meet the metal pipes, but leave approx 40mm of rubber hose on the end. Plug each of them with a 15mm swaged copper water pipe bung (from your local plumber or B&Q etc) and use a jubilee clip. Your alternative is to remove the pipes, cut the joins and weld a closing plate in place, but it's your call. HTH
