VW 2 litre 8v cylinder head. (Engine code,AGG) RED=Cut Faces. YELLOW=Exhaust Ports. GREEN=Intake Ports. NAVY=Waterways. ALLOY=Original Casting Open To Air. Head P/n = 048 103 373 Standard head, not reworked. Notes, 7mm valve stems, single springs, no steel spring perch washers as with the 8v Gti digifant head. Casting pretty uniform on all four port pairs. Intake valve diameter> 39.5mm. Intake valve seat opening> 34.5mm Exhaust valve diameter> 33mm. Exhaust valve seat opening> 29mm Sorry if the name tag is a bit in your face, its just easier than watermarking which takes an age. Brian.G.
Another great effort Brian - thanks for going to all the trouble Suggest updating your sig with this thread link?
The AGG head, naked in all its glory! Well done Brian! Chris, what are you doing in the 8v section? Thought it was beneath you. Or are you slowly coming around?
Ya, I must put all 3 in there and get rid of the youtube links, all 3 being the 8, 16, and 20v head which Ive cut too, just awaiting paint and camera
The sheer effrontery! You've far too many posts in the 16v section to be on stable ground talking like that!
