I've tried to search the forum with no luck My question is this, How much does the ABF engine weigh? with/without O2 gearbox Many thanks Ben
From various data around the forum: Block: 40.8kgs Crank: 14.5kgs Rods + pistons (4): 4.1kgs Sump: 1.5kgs Head complete, no manifolds: 26.3kg + Intermediate shaft, oil pump, crank seals, bolts etc All give or take for scale acuracy So ~90kgs easily & should be under 100kgs.
just had an ABF delivered on a pallet,no clutch or fly wheel,no gearbox,fairly big pallet 200 kg on the invoice
Maybe it has come in under that weight limit? All ancillaries there by the sounds, but surely it can't be 200?
yes your right i rang the company and they didnt have the exact weight ,200 was a rough guide,they say they always qoute over the weight to be safe and the engine probably weighs considerably less
