mk2 rev counter problem, 1.8t bam
Discussion in 'Electrical' started by Sc0rian, Dec 26, 2010.
  1. Sc0rian
    Sc0rian Forum Member
    Suffolk
    hi all,
    on my rallye, i'm running a late spec 1.8t bam engine. It's running all the oem ecu and what not. The problem I've had with it is I cannot get the rev counter to work. I can get it working on late spec corrado clocks, but as far as I'm aware the signal to mk3/corrado clocks are different than mk2.
    I have tried using a black box which you get from jabba and I ordered a more advanced one which allows you to set some settings to convert up to 12 cyls into 4 cyl clocks. This does work, but doesn't work on mk2 clocks still.. Vince at stealth told me to get it.
    http://www.bakerelectronix.com/products_tsd
    What should I do :(...
  2. tinydubs
    tinydubs Forum Member
    hold on.... i`ll take a look tomorrow i have a box of tricks that drives mine.
    originally i had problems with mine too, turns out it needed a better earth and live to prevent overheating. all thats inside is a coil and 3 pin diode
  3. Sc0rian
    Suffolk
    thanks bud :)
  4. Admin Guest
  5. tinydubs
    this is from QPeng, the transformer is a 35:10.5 ratio its very important the metal tab on the diode does not touch anything.standard part number is BD243C
    show here[​IMG]
    top pin 1 Ecu signal
    pin 2 coil black
    pin 3 Earth
    coil, show red 12v+ and black wire to diode pin2
    coil, showing brown 12v+ and blue to tacho
    hope this helps:)
  6. JWYATT Forum Member
    South Coast
    Qpeng said they wont sell just the convertor ... , but Jabbasport said they now make these kits ,?
    Jo :thumbup:
  7. tinydubs
    well thats it ^up there, mine came with the kit i can`t see it being expensive to make all the parts are standard consumables for a leccy.
    diodes are under2 from farnell, they also have lots of them, but the vagueness of the info i know doesnt help. i`m still looking
  8. tinydubs
    seems they are known as "bobbins transformers" they start at 8
  9. The_bug Forum Member
    Near Coventry
    I've been looking for this information since last summer and its so close to being possible to build but cant find a suitable transformer anywhere since they dont do it by ratio? Has anybody got any more info (even a manufacturer would be handy).
  10. Sc0rian
    Suffolk
  11. eazydaz Paid Member Paid Member
    it works correctly?
  12. badger5
    nr Glos
    question.... what signal do the mk2 rev counter clocks want to see?
    i have an s60 feeding pin 10 on instrument cluster, and scoped its signal output, which is a square wave dc switched output at battery voltage amplitude. rev counter wont work.. its run on an exp48 ecu before and worked, which is odd needless to say.
  13. rubjonny
    its a pulsed -ve mr badger, same signal as the TCI unit uses to fire the coil :thumbup:
  14. badger5
    nr Glos
    ahhh.. -ve.. doh!
    cheers
    wondering how the exp48 that was on there before managed to make it work.. ?
  15. rubjonny
    paging dr. Trev! :lol:
  16. The_bug Forum Member
    Near Coventry
    Another question. What do the original diesel mk2's use for the rev counter signal? no coil so no signal right.
  17. rubjonny
    comes from the alternator :)
  18. The_bug Forum Member
    Near Coventry
    Ah ye, just been hunting for info on the diesel forums. not much use without monumental effort... the hunt continues!!
  19. badger5
    nr Glos
    I think its more than just a -ve feed.
    Its getting that and no workie.. from S60 direct, and also off coil drivers direct.
  20. rubjonny
