ITB Manifolds
Discussion in 'Throttle bodies & non-OEM ECUs' started by Brookster, Jan 13, 2011.
  1. Brookster
    M1 J40
    Here's a couple of 16v ITB Manifolds .
    Thought i would start a thread with the range of types and manufacture to help anybody.
    Dbilas
    Pro Alloy
    I have DTH so not required , but found these when i was deciding what to go for.
    Please post any you have. :thumbup:
  2. Jools Forum Member
    Plymuff
    One i built, just for those among us who wants to build one:
  3. Vento Mike Forum Junkie
    Exmouth
    Did you do the tig welding mate? If so what tungsten / filler sizes did you use?
    Thanks!
    Just started messing with my TIG lots of practice needed!
  4. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    JMR dcoe style... to suit dcoe type bodies as well as carbs...
    Needs to be fitted with this tho...
    And a low radiator is needed...
    And there's plenty of clearance to the front panel (with a low rad)...
  5. Brookster
    M1 J40
    Don't know the make of this one found onthe forum ?
  6. Race Power New Member
    Kent
    I think the 8v crossflow inlet manifold is made by Chadil,bought one from Badger5.
  7. Toyotec
    From wippy748s
    16v TWM:
    Mangoletzi I can't find, but as they're rubbish, not a bad thing!
  9. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Mangoletsi... ;)
    [xx(] [8(]
    That would explain it! I still can't find a pic of the foulness that is the 16v inlet tho!
  11. badger5
    nr Glos
    TWM were nice. shame not available now. available previously in two lengths also
  12. danster Forum Addict
    KR / ABF 16v
    8v Crossflow
    20v
  13. Brookster
    M1 J40
    What make are all those Dan ? Has Brian G been busy doing castings.
  14. Carbs4ever Forum Member
    Portadown
    Used a Rowland one on mine – I think it was the MO62 (long) on the website
    http://www.manifolds.co.za/?page_id=41
    Needed a bit of work to it – like opening out the ports to suit the bigger carbs and some port matching – also middle brace removed to clear linkage – also used a swan neck water outlet from pierce manifolds usa
  15. James V Forum Member
    WOW, that is rather pretty
  16. TrackCab16v Forum Member
    Wales
    one off custom cast manifold to take bmw m3 throttle boddies to vw 16v head pics to follow shortly :thumbup:
  17. skint_golfer
    skint_golfer Forum Member
    Banbury
    possibly the fastest grass in town, that setups got to be worth an extra 25 blade horse power at least!!! :thumbup:
  18. Carbs4ever Forum Member
    Portadown
    if it was a 16v he could have double chop....
  19. Funky Diver Forum Member
    Darlington, UK
    But the grass would be shredded due to needing to rev the nuts off it ;)
    And yes Danny... who made the 8V crossflow one? And why is the Cam Cover on the wrong way around?
  20. Carbs4ever Forum Member
    Portadown
    the revs is where its at funky diver.....
