Inlet manifold designs - some science, inc cutting PB manifold up final cut done
Discussion in 'Engines' started by drunkenalan, Oct 10, 2011.
  1. drunkenalan Paid Member Paid Member
    Leicester
    recently / this afternoon, i have been investigating the differing styles of inlet for a upcoming project, which will require a custom manifold.
    So Audi / Lehmann seem to favour the tapered twin plenums which can be seen here @bufkin engineering
    i have also found this HPC - inlet design
    i would love to build one like this
    any other interesting designs out there?
  2. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Go on spill the beens Alan... what does it need to flow air into... strong hp 8v? [:D]
  3. Toyotec
    The guys at GS may have one of those if you want a looksie.
    Also have other types too for comparison.
  4. drunkenalan Paid Member Paid Member
    Leicester
    that would be good eddie, ill see if i can get a sneaky peak next time im there ;)
    i understand a little bit of the theory of the inlet design, but the one above puzzles me, why would the trumpets be tilted over at differing angles?
  5. drunkenalan Paid Member Paid Member
    Leicester
    oh it will definately be an 8v!! it will always be 8v Jason.
  6. drunkenalan Paid Member Paid Member
    Leicester
  7. drunkenalan Paid Member Paid Member
    Leicester
    some pics courtesy of HPR again
  8. drunkenalan Paid Member Paid Member
    Leicester
    So today i received a pb inlet (Thanks to MikeH) which will be cut up for my custom inlet. as i cut it up ill post some pictures.
    I thought that it would be good have a quick look and see what the plenum volume is and the total volume of the plenum and runners.
    the plenum holds about 1.8 litres of water, the same as the PB engine... coincidence? the runners hold about another litre of water, the total being 2.75 litres, i could maybe have squeezed a touch more in but not more than 2.8 litres, so the runners are about the .25 of a litre each. ill measure the lengths as we go.
  9. drunkenalan Paid Member Paid Member
    Leicester
    the manifold differences on the 2E and AGG
  10. Admin Guest
    There seems to be a clear difference with FI manifolds to NA, the FI often taper where as the NA have a flatter part to the direction of the inlet track. I would have a good look at OEM high performing NA engine manifolds such as Honda, Ferrari etc lots of pics on the net and these have proven to work. The 'after' market manifolds may not always be worth the money you pay, but then again most are FI.
    Big volume plenums (1.5 x engine cc or something like that cannot quit remember the figure!) with the entrance of to one side to aid air flow seem to be a good choice, rally cars, ferrari, etc
  11. Jon Olds Forum Junkie
    I have a couple of manifoldy projects on the go soon. I will try and persuade Chris to put up some photo's for discussion purposes.
    Bikes have started to use different length trumpets on each pot (fours: R1) to try and broaden the power band width. Worth trying?
  12. drunkenalan Paid Member Paid Member
    Leicester
    ok, so the first part of the PB inlet manifold cutting up exercise
    step one
    some pics from the TB end, no cuts at this point
    the furniture inside the manifold.
    im sure all that crap helps!!!
  13. drunkenalan Paid Member Paid Member
    Leicester
    step two - cut the TB mount flange off, i did this because i wanted to keep it for another day.
    took this pic, cos my arm was feeling it at this point
    never could make vertical cut!!
    view down number one
    incidently number one runner is 255mm from the top of the port to the floor of the plenum
    the rest will be measured as we go along!
    section bolted to a PB throttle body, a view you dont see very often
    next step, get some metal blades for the Jigsaw!! and slice along the length of the plenum, more to follow....
  14. drunkenalan Paid Member Paid Member
    Leicester
    did some more cutting tonight!!
    i have now measured all the runners using the same method, they are all within 2-3mm the same length, 255mm!! nice one VW
  15. alexisblades99 Forum Member
    sunny helsinki
    If your arm gets tired, stone cutting discs for the angle grinder work a treat on cast ally from what I've heard :thumbup:
    Are you going to add volume by building up the plenum?
  16. Mike_H Forum Addict
    Did anyone else get the optical illusion where that looks like a fish - head on the right, gills behind...
  17. drunkenalan Paid Member Paid Member
    Leicester
    funny i was looking at the 9 inch grinder sat there from when i did the patio thinking hmmm i wonder, i may just try it, now
    yes more volume is the main point for doing all this in the pic below, you can see a casting line 2/3 if the way up the runner, that i were i plan to make the next cut, the runners should be almost round by that point
  18. drunkenalan Paid Member Paid Member
    Leicester
    just you mike, altho now you have said it i can see it.
  19. simon cooper New Member
    I have 1 of the lehmann 4 cylinder inlet manifold on my 8v g60t.Ill post some pics as soon as i can.Im also in the process of building a G60 syncro with a 5 cylinder TTRS motor,the manifold on the rs motor is based on the lehmann design ill take a pic of that too.
  20. drunkenalan Paid Member Paid Member
    Leicester
    cool that would great, sounds like some interesting projects!!
