2L 8v - cant find it in the search
Discussion in '8-valve' started by NZ_Golf, Sep 2, 2004.
  1. NZ_Golf Forum Member
    London
    I am going to do the 2L bottom end conversion to my 8V Mk2, using a 3A Audi bottom end - but I just have a few queries that I need help with (if you wouldnt mind!)
    Is the 3A block is the same height as the PB? (Exhaust)
    What distributor setup would I use for a 3A block/PB head?
    Thanks in advance :clap:
    Edited by: NZ_Golf
  2. Unknown Forum Junkie
    same hieght so no worries about anything, and use the PB distributor. (double check it's the same size hole on each block and the gear that it meshes with on the intermediate shaft is the same of course, but you can always get an adaptor ring made for a couple of quid)
    Edited by: Unknown
  3. drunkenalan Paid Member Paid Member
    Leicester
    try the FAQ section i followed it and it helped
  4. Riley
    Riley Forum Addict
    Burnley/Lancs
  5. NZ_Golf Forum Member
    London
    Ahh great all sorted now thanks for that guys :clap:
  6. NZ_Golf Forum Member
    London
    Dragging things up from the dead, what does the adapter ring do? [:$]
  7. davey j Forum Member
    Hi all. Can the Audi ABK bottom end be used ok? I am able to get a low miler for next to nothing. I understand it superseeded one of the earlier Audi engines?
    Is to be used with a MK4/Beetle Crossflow head.
