MK2 GTI 2L 8V Conversion Problemo
Discussion in 'Engines' started by crazy_fox, Oct 30, 2004.
  1. crazy_fox New Member
    Hey, I'm in the middle of a 2.0l 8v conversion on my mk2 golf. Done it all but when i start it, it only lasts for a few seconds and found it was only running on one piston.
    After hours of testing and scratching of heads we finally put it down to the distributor. At the minute it's got the mk3 one but i'm guessing this isn't the right one. Does anyone know what to do???!!! [:s]
  2. Andy947 Forum Addict
    Scotland, Aberdeen
    You need to use a 2E distributor i think.
    Dont think the MK3 one is compatible, but i may be completely wrong :lol:
    Mk3 one is compatible if it is the same type as the Mk3 2E one (passat 2l, early Mk3 8v gti, etc..._). Take off the dizzy cap and see if the trigger wheel has one window in it, or 4. I'd bet it has one, whereas you need one with 4. The window is what gives you the spark - hence why you would only be getting the spark on one cylinder, if you have a single-window trigger wheel.
  4. crazy_fox New Member
    Yes this one does have only one window, the 2.0l engine is a '96 AGG so would make sense! [:D] Cheers for the help, hopefully it'll be running soon and will post piccies! [:^:]
  5. chrismc Forum Junkie
    Yup...2E dizzy is a must in an AGG block :p
  6. justadub Forum Member
    stateside
    try a msd 6al and fixed curve timing computer
  7. Mike_H Forum Addict
    Yup... AGG dizzy just has one sender pole, 2E & PB, etc have 4.
    You either need a 2E dizzy or an adaptor ring for the PB one.
