2L 8V Con Oil Pump Choice?
Discussion in 'Engines' started by domma, Apr 25, 2005.
  1. domma Forum Member
    Guys,
    When i finally get hold of a 2L block/crank/pistons for my MK1 conversion! I was going to put my "PB" hydrolic head on it.To do this i was informed to use the later oil pump that has more pressure to supply the hydrolic tappets.
    what if i use my old "DX" mechanical head instead. Would using the later higher pressure oil pump without the hydrolic tappets cause a problem with too much pressure in the engine?
    While i'm waiting for the block to come up i dont Know which is the best head to put my attention too.
    Anyone any ideas on this?
    Domma.......
  2. Unknown Forum Junkie
    oil pumps have a pressure valve on them, over a certain amount it opens and regulates it I believe.
