What dizzy for 2L 8v conversion?!
Discussion in 'Engines' started by JamesB, Jul 20, 2005.
  1. JamesB Forum Member
    Cambridge
    I'm doing a 2L 8v conversion into my Mk2 using the AGG block and in need of a definitive answer! So far I have 3 different options...
    Keep with my current digi dizzy
    Get a gear and plate from TSR
    Use a dizzy from a 2E block
    Any ideas?
  2. chrismc Forum Junkie
    You need the 2E dizzy! For certain ;)
    You only have 2 options there really - either you can use your own dizzy with the spacer ring and larger gear, or you can use a 2E dizzy. Both work exactly the same, but the 2E dizzy is a bit of a tidier solution...
  4. JamesB Forum Member
    Cambridge
    Right, i'll go for the 2E dizzy then! Imagine there are plenty around.
  5. drunkenalan Paid Member Paid Member
    Leicester
    got to be the 2e dizzy option
    work fine on my 2e block ;)
  6. Trinity Forum Member
    i used the PB dizzy and had no problems whatsoever, if you use the 2E dizzy you will need to buy an adaptor ring from tsr, why pay the extra cost?
  7. JamesB Forum Member
    Cambridge
    Hold on...does that not go against everything that has just been said?!!
  8. chrismc Forum Junkie
    WRONG!! [:s] The 2E dizzy fits the AGG block with no need for the ring & matches up to the PB loom... ;)
  9. farquare Forum Member
    Scotland
    no, like the TSC said use a 2e dizzy (will cost you the price of a new dizzy) or use your digi dizzy (which will no doubt cost you the skin on a knuckle changing the gear on the bottom over plus the price of a spacer ring, both do the same job.
    i had a digi dizzy with a diff ring & spacer an a 3a block, and am now using a 2e dizzy on a 2e block it will become apparent when you try to put it together what you need. [:D]
  10. TheSecondComing Forum Addict
    What you need is exactly as Farquare said - PB dizzy and adaptor gear/ring, or 2E dizzy. The PB dizzy has the wrong gear on the bottom, and is too small to fit in the dizzy hole in the 2E, 3A, or AGG blocks.....
    Don't ask for a dizzy from a Mk3 Gti tho, it will cost you more over one from the same 2E engine you can find in the '89-93? model passats.....
  11. seanlikesfood
    seanlikesfood Paid Member Paid Member
    Overton
    2e dizzy
    Just got a dizzy that i was told was from a 2e engine for my agg conversion. Does anyone know the part numbers for this dizzy so i can confirm i have the right one?
  12. Toyotec
    037 905 205 AX replaces 037 905 205 J
  13. seanlikesfood
    Overton
  14. Admin Guest
    i've got a dizzy from my mk1 2l conversion left
    mk1 dizzy with the gearing for the 2l block,
    if any one wants it?
  15. s24da Forum Member
    sheffield
    don't know if anyone will notice this but...
    if tsr are now closed, what is the alternative when it comes to their adapter ring for the dizzy when doing this conversion? i'm going to attempt the conversion with my k-jet, so if i read it correctly, i have to use the original dizzy from my block with the adapter from tsr, so does anyone know of anywhere else making this adapter? or have a spare one from an unfinished project?
    thanks
  16. maxmo
    maxmo Forum Member
    Co. Durham
    TSR are trading again
    You can contact them or buy it on ebay where they have an ebay shop:)
  17. Admin Guest
    came via TSR
  18. mr hillclimber Club GTI Supporter and Sponsor
    Southwest
    Track down domma on here, he did one for me a couple of months back, fits a treat. :thumbup:
  19. misteralz Forum Member
    The middle of nowhere, AB31
    Meaning a mk3 GTI dizzy will fit an AGG/ABK/whatever block but work with a PB head?
    I'm so confused. [8(]
  20. rubjonny
    you need a 2e or PB dizzy to work with the std MK2 GTI digifant injection system, the later AGG/ABK/whatever dizzy will not work as the hall sender pulse is different. Plus the later ones are keyed so they wont turn in the block!
    You fit your old PB head to the 2.0 block, and all your existing engine managment plugs straight in. If you were to use a 2e/AGG/ABK/Whatever head, you cant fit your old inlet manifold to it so you would have to convert to the 2e/AGG/ABK/Whatever injection system :)
