mk2 2l 8v gti rev prob
Discussion in 'Engines' started by farquare, Aug 26, 2005.
  1. farquare Forum Member
    Scotland
    have a strange problem with my mk2 2l 8v gti, when i hold the throttle open in neutral gently so it rises slowly to about 2200 rpm every now and again it falls back down to idle then builds back up even though my foot doesnt move, im thinking throttle swiches on top of the inlet manifold, thoughts please
    doubt it'll be the switches, one is for when the throttle is closed and the other is for when its wide open, could be an air leak or possibly the ISV?
  3. Mike_H Forum Addict
    ^What he said^ ....more likely ISV
    Soak it in paraffin for 24 hrs and see if that helps.
    ...and don't use carb cleaner as the stuff is abrasive, use petrol/white spirit/Vodka etc :)
  5. Mike_H Forum Addict
    NNNNNNNNOOOOOOOOOOOOOO!!!!! Don't waste vodka on it!!
  6. justadub Forum Member
    stateside
    or maybe its the idle air valve fogive me if this has already been told im new here trottle body cleaner will prop be the best thing to clean with
