2 litre 16v rebuild
Discussion in '16-valve' started by GVK, Feb 28, 2006.
  1. GVK
    The 9A that's been in my mk2 for the last nearly 4 years has come to the end of it's active life, the crank is growling like a mk2 Chavalier running on cooking oil, and it's used 2 litres of oil in as many weeks.
    It was a 300 second hand engine out of a fire damaged car with unknown mileage/history, so it's done well to last 55,000 miles in the mk2 with the amount of track days and stuff it's done.
    I know I have babbled on about going VR6, but to be honest I like the simplicity of the 16v and it's a well tried and tested unit for track use, so with that in mind I started looking for a replacement 9A/6A short 16v block to build up.
    I've added these pics to my member's motors thread ..
    6A 2.0 16v rescued from Barny's garden.
    On the engine stand at work Saturday lunchtime
    Head off sump removed
    Bore shot, hmmm could do with an 83.5mm rebore methinks
    Hmmm,those piston rings have been blowing by...
    That 92.8mm crank looks a bit heavy....
    Taken the crank and block down to Martin (Hotgolf) he's lightening and knife-edging the crank and getting it balanced, the intermediate shaft bearings are fecked so he's got to sort those out.
    Block is going to be bored +40 (83.5mm) and with the 92.8mm crank it should give 2033cc or 2035cc depending which calculator you use.
    I've just this evening ordered from the USA a set of JE racing pistons with 10.8:1 CR and a set of those cheap Scat steel rods that are just too cheap not to give a whirl ($319 USD). http://www.importperformanceparts.net/
    Hopefully should be a nice strong bottom end when we're finished all being well..
    I'll run it on the same flowed head and modded inlet/exhaust cam set up for now, but the foundations should be there to add cams or whatever at a later date.
    (here we go again!!) :lol:
    Edited by: GVK
  2. STU
    Stu Forum Junkie
    Cheshire, UK
    The 6A is the engine of choice Gary, good work! ;)
    Sounds like it'll be a powerhouse once Hotgolf's done his bit and it's back together with all those new parts. Do you think your gearbox is up to it...? :p
  3. GVK
    6A/9A same thing really, different sump, I've thrown most of it on the scrap heap. :lol:
    Gearbox will either last or it won't :lol: Since Martin re-re-built it it's been fine since September
    (Including 3 full open pit lane track days)
    Edited by: GVK
  4. ViCk Forum Member
    You may aswell ditch k-jet and go throttle bodies !
    Nice work by the way :)
  5. GVK
    One thing at a time:lol:[:$]
  6. darrynK
    darrynK Forum Addict
    just supercharge it then[8D]
  7. PhatVR6 Forum Junkie
    nice one GVK. Always nice to see someone planning their next mods when something goes wrong rather than throwing in the towel.
    ITB's would be sweet, shame they cost so much.
    200bhp at last maybe?!
  8. jimmy8v Forum Member
    Sounds very nice indeed.Bulletproof springs to mind. Can i recommend arp mains as well to complement a particularly strong package.
    /Party Pooper Voice
    I'msure you're aware but the rods will need rebushing(scat cocked it up). No big deal though.
  9. fthaimike Forum Addict
    Will be interesting to compare the old & new one gary when it is all finished [:D].
  10. GVK
    Spent too much on the rest of the car getting it how I want it to drive on track to throw in the towel, I'd never get it back, so just got to keep plodding on:lol:
  11. barny Forum Member
    Lost in Glos
    Feck me thats gonna rock ! Dammit boy your car keeps getting faster and mine collects more dust ! :lol:
  12. I V - mk1 16v Forum Member
    Queensland, Australia
    Should be monster! [:D]
  13. Hotgolf
    Smelly Cornelly
    The rods will not require re-bushing, the tall block rods they do came with a 20mm wrist( ;) ) pin instead of 21mm, but if you buy the JE pistons cheap then you're sorted.
    And, as these are the 144mm rods the pins are 20mm so no probs there.
  14. GVK
    LOL @ wrist pin, I'm sure your phone redirected my mobile to USA and used all my credit. :lol: It's all a disguise this Welsh stuff I tell ya :lol:
    Edited by: GVK
  15. GVK
    If like me you're not so good with ETKA found a US site with loads of engine parts for 16v's etc all with VAG part numbers.
    http://www.qualityvwparts.com
    Might come in handy when ordering parts for this engine..
    056 198 451sp Main Bearings
    1.7-2.0 8V & 16V All
    (OE Style Bearings
    Seperate Thrust Pieces For Extended Life Over The Widely Sold Integral Thrust Bearings.
    These Bearings Are Superior to Part # 056198451a ) ........ interesting?
    034 198 501Big end bearings (STD)
    037 115 220b windage tray
    056 198 521 aux shaft bearings
    048 103 383b head gasket ? Anyone know the pn of the proper metal gasket as used on the later 9A?
    068 103 051G rear main
    026 103 085d front main/int shaft/cam seal x3
    056 115 037 int shaft housing seal
    056 103 161 front main seal carrier gasket
    052 103 181 rear main seal carrier gasket
    n100 113 401 clutch bolts (fw - cpp)
    n902 06 103 crank/cpp bolts
    051 115 105a oil pump
    051 103 623 dip stick guide tube.
  16. Hotgolf
    Smelly Cornelly
    S h i t, you got me, I was gonna give you back a shoddy bomb casing full of used pin ball machine parts....
    88 miles an hoooooooooooooooooooooooouuuuuuuuuuuuuuuuuurrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrr!!!!!!!!!!!!!!!!!!!! :lol:
    Edited by: Hotgolf
  17. GVK
    Martyyyyyyyy (n)!!!
  18. mk1. Forum Junkie
    looking good :p they dont take long to strip onece you get into them,just hope the taxman doesent sting you again [:x]
  19. GVK
    Let's hope not Louis :)
  20. badger5
    nr Glos
    Can you elaborate?
    I am running rods which are'nt Scat but look very similar... and have small end rattle. I suspect material in the rods small end bushes.
    What do you do to make em good again? (replace them with amco bronze/aluminium bronze bushes or something?)
    thanks in advance
    bill
