THE 2 litre 8v thread
Discussion in '8-valve' started by JamesB, May 13, 2006.
  1. JamesB Forum Member
    Cambridge
  2. chis New Member
    Which water pump?
    In the 8V 2L coversion do you keep the A3 water pump?
  3. JamesB Forum Member
    Cambridge
    IIRC the MK3 and the MK2 8v water pumps are the same. So you can use either.
  4. gregmk2 New Member
    oil leak around distrubutor on mk2 2l 8v
    I recently had a 2l conversion for my 8v mk2 done, but it has developed an oil leak around the area by the dizzy. i took it back to the garage that did it and they said that apparantly the mk3 block uses a different seal here and that they made one up for it. but as it is leaking they said they have to order a special part for it, fine i say. but problem is i've been waiting 2 months and still no part and i'm gettin annoyed with my car dropping oil when it has been fully rebuilt! anyone know anything about this? or what i can do about it?
    sorry for the waffle and i hope i have made myself clear,
    greg
  5. Mad Micks Forum Member
    Just completed my Mk2 2.0 conversion and it's magic! [:D]
    So much more low down torque and power; you can really feel the difference. :)
    Managed to fit a Mk3 camsgaft cover and cam belt covers. ;)
    No downpipe problems - it fits a treat.
    All I can say is, do it! :)
  6. skattrd Forum Member
    I'm thinking about a 2l conversion for my scirocco (1.8 8v dx) but most of the articles relate to mk2 Golf. Is it the same for the dx and which bottom end should I use 3a/2e?
    Thx
    Chris
  7. fthaimike Forum Addict
    Does anyone bother with the 1.8 short block bored out & with the diesel crank nowadays for their conversions?
    Just wondering because that's what mine came from in the mk1.
  8. Phil. Forum Junkie
    Northern Ireland
    I looked into it but the extra expense of boring then fitting new pistons or oversize rings against the price of a 2.0, just made more sense to go with a new block at 100.
  9. fthaimike Forum Addict
    Yeah that's why i guess you dont see them now & much more scope for the mk2 jobbie's.
  10. seanlikesfood
    seanlikesfood Paid Member Paid Member
    Overton
    Inlet Manifold on 2L conversion
    I suspect a few people will laugh at this!!
    Have just fitted my new engine with AGG block, whilst putting the engine in I neglected to fit the inlet manifold on as I was missing 2 of the studs.
    The Haynes manual says to fit it with the the engine in situ is not possible!! this is slightly upsetting to me as it is almost complete and it was a real pain lining up the engine mounts when i fitted and I really do not want to go down that road again in a hurry!
    Has anyone out there managed to remove and fit one with the engine in situ? If so any tips? I gather as the block is slightly taller does not do the task any favours!
  11. PhatVR6 Forum Junkie
    got one for sale if anyone is interested.
  12. VwBen New Member
    Southampton
    Has anyone considered doing a guide? I currently have a mk2 golf 8v gti but would really like to do the 2l 8v conversion but i have no idea of the cost of the conversion or what needas to be done, can anyone make a rough list or something and pm me?
  13. fthaimike Forum Addict
    Have you clicked on the links in the 1st post?
  14. VwBen New Member
    Southampton
    lol yeah sorry, didnt see the very first post????
    opps, can someone explain to me what a big valve head is?
  15. JamesB Forum Member
    Cambridge
    A big valve head is exactly that, a cylinder head with larger valves fitted!
    Larger valves = more air into and out of the engine.
    Usually a big valve head takes the exhaust valves from 33mm to 35mm and the inlet valves remain the same, these are generally known as stage C heads. Stage D heads have slightly larger inlet valves. From 40mm to 40.5mm if i remember correctly.
  16. fthaimike Forum Addict
    More porting/removal on the D & slightly different valve shape/finish.
  17. Setone Forum Member
    2.0 8v 2E engine Which Gearbox etc
    I'm gonna be changing my 1.8 for the 2.0 2E block in the next coming weeks. can i do a striaght swap gearbox, clutch fly wheel wise. how long should it take to do a weekend?
    Also does bocking the block breather afect the runnig of the engine?
    oh 1 other thing would a super sprit exhaust mani 4-2-1 fit as the block sits 20 odd mm higher
    cheers
    Paul
  18. KR MAN Forum Member
    'Ull
    Everything does swap over, make sure you use the 2E 4 trigger window dizzy, or the adaptor ring from TSR. For the manifold use the mk3 one for a perfect fit.
  19. justadub Forum Member
    stateside
    hey can anyone give me a rough est.of what a 2l block gasket matched head with autotech 270 cam valve springs,header 2.25inch exaust and a75hp shot of laughing gas will put to the ground
  20. C12AIG Forum Member
    Chippenham
    A 2.0 bottom end is that? Which one?
