Results 1 to 3 of 3
Thread: Help: EKTA 7 install error
    Forum Junkie G60Dub's Avatar
    Oct 2003
    Angus
    2,682
    34
    Default Help: EKTA 7 install error
    Hi folks,
    Just tried to update my Ekta 6.31 with 7 and I'm getting the following error at the begginning of the instal:
    This system is no fatclient or ETMaster 2000 Server. The installation will be aborted.
    Any ideas if its perhaps related to a service thats not running?
    Bora 4-Motion
    Forum User golfgtd's Avatar
    Sep 2006
    UK
    208
    Probably because etka 7 is completly different. They have completly changed it from how it was.
  3. #3
    Forum Junkie
    Mar 2004
    Northern Ireland
    4,275
    Are you installing it from the HD of the pc you intend to put it onto? If so that is your problem.
    Burn it to a DVD, delete everything that says ETKA form your HD, restart pc then reinstall.
    This site is very useful and tells you everything you need to know about install problems and fixes and how to setup regions, currency and VAt etc..
    I really should get this sticky'd sometime as I've posted this about a dozen times now
    K-jet kicked in yo!
    Quote Originally Posted by Jolfa View Post
    just wanna get it working before I start worrying about little trivial things like safety!
