Hi folks, Just tried to update my Ekta 6.31 with 7 and I'm getting the following error at the begginning of the instal: This system is no fatclient or ETMaster 2000 Server. The installation will be aborted. Any ideas if its perhaps related to a service thats not running?
Are you installing it from the HD of the pc you intend to put it onto? If so that is your problem. Burn it to a DVD, delete everything that says ETKA form your HD, restart pc then reinstall. This site is very useful and tells you everything you need to know about install problems and fixes and how to setup regions, currency and VAt etc.. I really should get this sticky'd sometime as I've posted this about a dozen times now
