Results 1 to 7 of 7
Thread: Rust spots on MK2 :-(
    Forum User Phlarris's Avatar
    Jul 2004
    34
    Question Rust spots on MK2 :-(
    So, my beloved MK2 is starting to show it's age a bit...
    There are a number of small rust spots (less that the size of a 5p coin) on the bottom sections of the doors.
    What is the best way to deal with them? I guess they'll need sanding and treating? However, this will leave me with a spotty car .Is there some other magic treatment that I could use?
    Phil
    Forum Junkie
    Oct 2003
    cambridge , uk
    13,513
    theres no magic treatment im affraid
    dremel away at the scab until its clean metal , keep going at the pits until its all clean
    then some zinc or etch primer , fill any pits so its flat , prime again and then paint
    if theres so many spots it looks bad then you will have to consider painting the whole panels..but at least the touch ins will slow the rot a bit
    91 G60 ed1 , 89 16v gti , 88 breadvan
  3. #3
    Forum Junkie MK3_GPP's Avatar
    Oct 2003
    Staffordshire
    1,058
    Quote Originally Posted by Phlarris
    Phil
    Do you have any pics?
    Is it just surface scabs, or is it pitted badly?
    MK1 GTI ~ TSR 1.9 8v - T4 ~ 1.9 TD - LUPO ~ 1.4 16v - LUPO GTI ~ 1.6 16v
  4. #4
    Jul 2004
    34
    No pics at the moment. However, they're only surface scabs. I just don't want a spotty car It's metallic green, so no chance to patch it up without respraying the whole panels.
    Oh well. I may post a few pics.
    Phil
  5. #5
    Forum User
    May 2006
    Sheffield
    140
    Best to deal with it now while it is only surface rust. Leave it and it WILL spread cost more time and money in the long run...
    Mk1 Golf GTI 1600
  6. #6
    Forum Junkie
    Oct 2003
    Scotland, Aberdeen
    10,455
    Bilthamber rust removal gel is AWESOME!
  7. #7
    Oct 2003
    Staffordshire
    1,058
    As said, if it just surface rust, get it sorted as it will soon start pitting. Even if you remove and cover with hammerite untill you get a respray it will help for the short term.
