HRP
Results 1 to 7 of 7
Thread: Lowering a 87 VW Caddy ?
    Forum User
    May 2004
    10
    Where can I get a lowering kit for my 87 VW Caddy.
    I've been told the back needs the axle removing and puttin back in above leaf springs but there should be a kit available for the front and dampers for the back ?
    None of my suppleres list a kit for the car so I'm guessing its a specialist product ?
    Jay
    Forum Junkie
    Oct 2003
    Albania
    3,344
    this set have been sold but the seller may be able to tell you where they got it from
  3. #3
    Forum User
    May 2004
    10
    Cheers I've PM'd him
    Anyone else have any info ?
  4. #4
    Forum Junkie
    Feb 2004
    1,577
    I'm kinda guessing but is the front the same as a mk1 golf, if so you can get hold of that easily enough.
    Mk1 golf GTD *
    Mk1 scirocco Gli in bits
    Club GTI membership number: 14603
  5. #5
    Dudboy
    Guest
    right check out www.vwcaddyforum.com loads of info on there,
    off the top of my head GSF supply such a kit, you can use normal springs up front on the rear, on the rears you need to relocate the axle above the leaf springs rather than under it, its a fairly simple mod to do with a bit of DIY chucked in, also check out www.bullock-style.de they do loads for caddy's.
  6. #6
    Forum User
    Dec 2003
    189
    There's an excellent 'how-to' in this months Golf mag!!
  7. #7
    Forum User
    May 2004
    10
    Quote Originally Posted by ewang3
    Except that it will cost you £££'s I can offer a converted rear axle for a fraction of the cost and its stronger (as per factory), PLUS those cumbersome kits weigh about 12 Kilos
    More info on the axle flip here
    [center]
