Results 1 to 8 of 8
Thread: MK3 Fuel Pump Removal
    Forum User
    May 2008
    Exmouth
    735
    Default MK3 Fuel Pump Removal
    Hi Guys,
    Can anyone give me some info on how to remove the fuel pump from a mk3 golf? I had a look last night, removed inspection cover, pulled out the fuel level gauge sender/float but cannot remove the actual pump. Haynes says to turn it anticlockwise, however i can only turn it a little and it still won't lift out.
    Advice much appreciated chaps
    Nick
    its not a car its a volkswagen
    Forum Junkie G60KG's Avatar
    Sep 2007
    at work 'working'
    2,771
    the pump is on the actual float sender assembley. you need to undo the jubilee clip on top of the pump and disconnect the terminal. Gently use a screwdrive to loosen the rubber hose where it is attached to the pump then just pull it off.
  3. #3
    Forum User
    May 2008
    Exmouth
    735
    Isn't that how to remove it on a mk2 where there is a lift pump and a main pump under the car? Mk3's there is only the 1 pump which is in the tank.
  4. #4
    Membership Team Sukh's Avatar
    Jan 2004
    the driveway
    502
    Its best to start with very little fuel in the tank.
    You twist it one way as its clipped into the tank and then navigate it out.
    Golf MK3 16V ABF
  5. #5
    Forum User
    May 2008
    Exmouth
    735
    Are they hard to twist to release from its fitting? I didn't want to turn it too hard as didn't want to break it .
  6. #6
    Jan 2004
    the driveway
    502
    they can be a bit hard so give it a bit of welly.
    Golf MK3 16V ABF
  7. #7
    Forum User
    May 2008
    Exmouth
    735
    OK thanks for your help will give it another go at the weekend see if i can get the damn thing out
  8. #8
    Sep 2007
    at work 'working'
    2,771
    Quote Originally Posted by nickh89GTi
    oh I thought it would be the same or similar as I just replaced the lift pump on the Corrado so assumed mk3 would be same sorry.
