Mk2 16v Water pump pulley
Discussion in 'Engines' started by Ticalion, Nov 4, 2009.
  1. Ticalion Forum Member
    Newcastle
    The idler pulley on my 16v is totally borked.
    I've just rang VW and the part is now obsolete, what options do I have?
    Is there a similar idler pulley on the Corrado or am I going to have to change to a mk3 alternator/serpentine belt stuff?
    Thanks, oh its got PAS too.
  2. tonyR Forum Member
    somerset
    Hi, I have the same problem myself, makes the engine sound like a bag of bolts! Have tried euro,gsf and a few vag specialists with no luck. Will have to settle for a used one if I dont find one soon. Good luck with your hunt!
  3. Ticalion Forum Member
    Newcastle
    Gonna take it off tomorrow and see if I can get either a new bearing or just weld it up.
    corrado kr & 9a will have what you want, either straight swap or the alternative 16v pulley setup which doesnt use a slipper wheel. if you get the other setup nick all the pulleys off it then you know you have what you need.
    If it was me I'd go for the MK3 setup as you say, much better and easier to get parts for. You can get everything you need from a 1.8-2.0 8v or 16v MK3, just the crank pulley that is 16v specific. you need:
    alternator
    alternator bracket
    pas pump
    pas brackets
    all the fixings you undo to get them above off
    belts to suit the above
    note there are 3 alternator belts available based on the year/model. MK3 A/C setup will also work, just you'll need to get a non-a/c waterpump pulley. Everything else is the same though :)
  5. Ticalion Forum Member
    Newcastle
    Well i got the three allen head bolts out but can't get the bugger off :/
    Gonna have a look to see if I can get the newer bits locally for a reasonable amount.
    Thanks for the help
    can be a pain, wiggle & yank, eventually it'll come off :lol:
  7. Ticalion Forum Member
    Newcastle
    Eventually got it off, its a strange thing.
    Its worn on the faces between the pulley and the centre, not the bearing, it wobbles from side to side.
    Think I can probably get a spacer machined up.
    Will let you know how I get on
  8. Ticalion Forum Member
    Newcastle
    Right I couldn't get a spacer machined up as its gonna be too small :(
    I've just picked up a pulley from a Corrado 9a, it's the same size as the slip pulley of mine but just pressed metal.
    Now the problem I have is that the offset is wrong, can anyone tell me if there are different shaft sizes on the water pump between a KR and a 9A
  9. rubjonny
    nope waterpumps all the same, you'll need all the other pulleys off the 9a to bring it back into line.
  10. Ticalion Forum Member
    Newcastle
    I've made a spacer for the water pump pulley, hope it works.
    Cant imagine a 9a crank pulley being cheap from VW, ABF one is 300!
    I'll let you know how I get on tomorrow, cheers
  11. Ticalion Forum Member
    Newcastle
    It lives!
    Made a spacer from the old slip pulley centre, put the new 9a water pump pulley and the old KR PAS pulley back on with the new belts and its working great.
    Altho I tightened the belts up a bit too tight and it sounded like a G60 LOL!
  12. rubjonny
    nice one :thumbup:
