Chemical cleaning of alloy parts
Discussion in 'Engines' started by Brian.G, Jun 21, 2010.
  1. Brian.G
    Brian.G Forum Member
    West of Ireland
    Ive done a few and I normally bolt in nylon plugs under caps to protect Journals. I like to be careful though...
    For the lifter bores I slide in plugs also.
    Im sure you could use some sort of barrier cream, that caustic wont eat too...(cant think of any)
    Im not going to say if dipping unprotected would effect things, I doubt it would really, but Im not saying either way.
    For nitric de-smut ALL steel items must be removed. Dont forget the spring perches, they can stick there un noticed sometimes.
  2. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Glad this thread popped up. Couldn't find much info on the net about this.:thumbup:
  3. walkinginperu Forum Member
    Leamington Spa
    Cheers, i've got a spare cylinder head and the g/f works as a chemistry researcher so i'll give it a go!:thumbup:
  4. oldnick
    oldnick Paid Member Paid Member
    Farnsfield, Notts
    Holy thread resurrection Batman!
    Having cheerfully bought the scabbiest engine mounts in the land I went to buy some nitric acid, nope not going to happen.
    Turns out that it can be used to make explosives, and as such can't be bought by plebs like me.
    So, do we have any chemists in our midst who can suggest alternative chemicals to remove the smut from the alloy?
  5. Tristan
    Surely by now, there's someone local doinf vapour blasting?
  6. oldnick
    Farnsfield, Notts
    Where's the fun in that? Although it would sort out the issue.
    In the meantime I've bought a cheapo soda blasting gun, see if it's any use at the weekend.
  7. dodgy
    Red diesel? cheap and reasonable for cleaning, also good for painting sheds, modern creocote doesn't quite cut it for me.
  8. oldnick
    Farnsfield, Notts
    Ye gods, a drop of normal diesel stinks, the wife wouldn't let me back in the house!
  9. dodgy
    I'm very lucky, my wife when we went on our first date at the science museum in Manchester told me she loves the smell of oil and old things, so ticked the boxes :)
  10. bootsie Paid Member Paid Member
    Brackley, Northants
    I've used RaceGlaze AluBright with some success on mucky inlet manifolds.
    AluBright Deoxidiser (500ml) RG71-500 (raceglaze.co.uk)
