Results 1 to 17 of 17
Thread: Adjusting Actuator & N75 Valve & AUM/AUQ Sort your boost leak issues thread...
    Paid Member Richard Mk2's Avatar
    Apr 2007
    West London & Herts
    12,098
    1,362
    Exclamation Adjusting Actuator & N75 Valve & AUM/AUQ Sort your boost leak issues thread...
    I recently had my Mk4 Golf AUM re-mapped by Custom-Code.
    Been reading various threads and info on the net, and apparantly the factory Actuator is adjusted to match the standard boost.
    Now that its running over 200, to get the car to boost at increased PSI, would require the Actuator to be slightly adjusted.
    How would i go about adjusting the Actuator. I heard you only need to turn a couple of threads at a time (on the wastegate settings/locknuts) max and mark the original position, too much and it could blow the turbo!!
    Any more info on this?
    Also, has anyone adjusted theirs and noticed an increase in boost. Mine seems to feel underpowered the last few days.
    Could be due to a faulty N75 valve perhaps.?
    Ive heard that you can adjust the amount of air which should leave the N75.
    If you adjust the N75 to the right, you will "close" the N75 valve, so just a few amounts of air is vented from the wastegate which will result in a lot smoother drive (eliminating surging, because the boost will be more constant), BUT at the same time it will introduce more boost to the wastegate, causing LESS overall boost. Adjusting the N75 valve to the left will "open" it, enabling more air to escape from the wastegate when N75 is opened, which will result in more boost (because wastegate wont open), BUT at the same time it MAY cause surging as the N75 opening/closing will be more obvious.
    Is this also true?
    Apr 2007
    West London & Herts
    12,098
    1,362
    bump.....
  3. #3
    Club GTI Sponsor and Supporter
    Oct 2003
    nr Glos
    5,900
    dont adjust the actuator.
    the ecu has request boost which is measures via map sensor and n75 valve regulates boost to the actuator. if you adjust wrong way and cause a deviation over 250mb it will drop into limp mode.
    if its running fine, no benefit or reason to adjust this
    BADGER 5 LTD: PERFORMANCE TUNING
    RACE PROVEN PRODUCTS & HONEST ADVICE:
    Contact:01453 822880
    Bespoke Big Turbo conversions,Forge,Ferodo,AP,Custom Code,REVO,H&R,Eibach,Vibratechnik,SPEC,Compmotive, DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more...
    http://www.badger-5.com
    email me at:bill@badger5.co.uk
  4. #4
    Moderator MUSHY 16V's Avatar
    Jan 2008
    aberdeen
    9,555
    1,104
    don't know bud i only have a tdi but if it over or under bosts it go's in to limp mode = no power
    vac leak or MFA would be my guess to the loss of power
    number 1 vac leak
    Remember and check your membership renewal date
    Paid membership only £10 in the club shop now with paypal click here
  5. #5
    Apr 2007
    West London & Herts
    12,098
    1,362
    Quote Originally Posted by badger5 View Post
    Thanks for the reply. Will not adjust the actuator then.
    Dont want to cause myself more problems.
    Dont get me wrong, the car does feel quick, but seems to loose steam up the rev range.
    Also when at the lights after driving, it doesn't seem to pull off as quickly. But if i turn the ignition off, then on again, it has more boost and feels quicker?
    Could the N75 be faulty? Or maybe a boost leak somewhere.
  6. #6
    Apr 2007
    West London & Herts
    12,098
    1,362
    Quote Originally Posted by MUSHY 16V View Post
    number 1 vac leak
    Im thinking there maybe a boost leak somewhere.
    Are there any common places to check?
  7. #7
    Forum Junkie
    Sep 2006
    Newcastle upon tyne
    1,971
    Vac or boost leak is top of the list!
    the pipes by the dipstick are prone to splitting,also the PCV and breather that comes from the rocker.
    Get the magnif/glass out mind as they are hard to spot.
  8. #8
    Apr 2007
    West London & Herts
    12,098
    1,362
    Quote Originally Posted by turbotommy View Post
    Going to give it a good going over tomorrow.
    I recently replaced the y shape breather pipe on the right side of the head, as this was split before. Wish i had replaced ir with a silicone one now though.
  9. #9
    Apr 2007
    West London & Herts
    12,098
    1,362
    Also, would a boost leak suggest why it runs better when turned off and on again?
  10. #10
    Apr 2007
    West London & Herts
    12,098
    1,362
    http://forums.vwvortex.com/showthread.php?3111538
    Just found this thread on Vortex.
    Could you really get away with removing the SAI, N249, PCV and EVAP, with out throwing up error codes ect...
  11. #11
    Forum Junkie Matt82's Avatar
    Apr 2006
    GTI Scene
    32,434
    19
    dont touch the actuator
    for boost leaks look under the unlet manifold where it goes to the breather system
    i fixed two today, its that common, and then one had a dead one way valve too.
    tested for boost leaks and only found them around the dv connections
    also, if your dip stick tube is broken then it will be dragging in unmetered air
    Got an M3 instead
  12. #12
    Apr 2007
    West London & Herts
    12,098
    1,362
    Quote Originally Posted by Matt82 View Post
    I did recently replace the y shaped breather hose, and also noticed that the pipe beneath the inlet manifold had a little split. I basically wrapped a rubber hose around it, and jubilee clipped it tight.
    But going back to the Vortex link above ^^^ the guy has completely removed all the pvc system, plus others.
    Would it not cause any problems?
  13. #13
    Apr 2006
    GTI Scene
    32,434
    19
    yeah, it needs a pcv system just like any engine
    the one under tha manfold that goes to the one way valve and pcv, if its split, you can split it and bung it with a bolt etc. thats a good temporary measure
    Got an M3 instead
  14. #14
    Apr 2007
    West London & Herts
    12,098
    1,362
    I suppose its worth replacing then
    I guess it would be a good idea to replace the vac hoses with silicone replacements, to prevent any leaks in the future.
    Its just so hard to get to the ones under the manifold. Even before when i temporally fixed the broken one, even with the metal plate out of the way it was awkward!!
    Also dipstick tube is ok as i checked this for the common splits
  15. #15
    Apr 2006
    GTI Scene
    32,434
    19
    there are two 5mm allen bolts to remove the tray. three 10mm bolts to detatch the sai hoses and then the n249 can be swung out the way... then youve got access to your breather hoses
    Got an M3 instead
  16. #16
    Forum Junkie
    Sep 2006
    Newcastle upon tyne
    1,971
    I run an AUQ daily driver which is the same an an AUM,i also have the same sort of vac/boost leak problems,my "Y" pipe is split amongst others and i must sort it all out.
    One of the problems is the N249 pipes are a maze and not easy to get to without snapping your dipstick etc...
    What we need is a good AUM/AUQ sort your issues thread
    I put this highest in the list before engine tuning as you'll never get it right before sorting these issues.
    No point turning up the boost for it to leak more
    Interestingly other engine codes of simlar age use hard pipes and different config's for the breathers and i think a catch tank is the way forward with the "Y" pipe,its just a matter of going through the whole system bit by bit eliminating leaks or problems but a step by step guide is what people need (IMHO)
  17. #17
    Apr 2007
    West London & Herts
    12,098
    1,362
    Great idea Turbotommy!!!
    This diagram may help -
    This guy has completely replaced everything with silicone hoses!!
    Thats what im aiming for tbh, but will all be in black
