BBS 15" RA Wheel Bolt Size?
Discussion in 'Wheels and Tyres' started by Cyrill, Jul 6, 2010.
  1. Cyrill New Member
    I recently bought a set of 7 x 15" BBS RA Wheels. The wheel bolts I have are not long enough, does anyone know the correct size bolt and any recommendations on where to buy them?
  2. afbiker02
    Bury St. Edmunds
    The guys at Demon tweeks help me out alot when I was looking for new bolts for my mk2
  3. Gambit
    Gambit Paid Member Paid Member
    standard shoulder VW wheel studs should fit no probs? thats what i use on my RM's
  4. muppet9966 Forum Member
    Uxbridge, United Kingdom
    I used the standard ones on my RA's.
  5. rubjonny
    early steely bolts were shorter, the ones you need are m12x1.5x23.5.
    this is assuming they're gen VAG RAs and not beemer ones
  6. cometbluecoupe Forum Member
    If they are 7 x 15 they will be beemer ones and probably need longer taper seated bolts as opposed to the radius head vw type. Not sure on the exact length needed though to be honest.
    D
  7. rubjonny
    use beemer bolts if they're taper seat.vw thread and a little longer than oem bolts :thumbup:
  8. Cyrill New Member
    Thanks all. They are Beemer ones as they're tapered. I measured a thread depth of 23mm through the wheel, is it normal to add 10mm to secure to hub?
  9. rubjonny
    kk just get a set of beemer bolts from zee scrappy and job done :)
  10. Justbe Forum Member
    Hello, I just bought a set of 15" BBS RA (6" wide ET35) with OEM number: 165601025. They should be the original VW Golf GTI mk2 wheels according to the serial or?
    Anyway it feels very weird to tighten them up with the normal radius/ball seated bolts. I think they should be tapered seated bolts, is this possible? :S
  11. jamesa Forum Junkie
    Abz
  12. Justbe Forum Member
    Thanks for the quick reply! When I tighten the bolts it feels like the bolts stop quite suddenly and it's a full stop. Could it be just a difference between a normal steel wheel compared to the aluminium wheel? The problem is that even though the bolts are tightened well, the wheel has a tiny tiny bit of play. Could be the bearing though... I will try it with the steel wheel and if it has the same play, I'll check the wheel nut. :)
  13. graham989 Paid Member Paid Member
    Lincolnshire
    You could have corrosion in the thread on the hub.
    Run you're bolt down the thread with no wheel on to see if there is a stoppage. If there is try running a tap through it to clear it out.
    Then retry the bolt to make sure it's clear.
  14. Justbe Forum Member
    Thanks graham! Have to check this out :)
  15. rubjonny
    yeah those should have a ball seat, if you're worried squish some bluetac in the hole see what shape it is. but regardless of the taper even with the wrong bolts in the wheel shouldnt have any play once they are tight so it suggests as above issue with the thread in the hub
