Results 1 to 4 of 4
Thread: leaking water pump and radweld?
    Dudboy
    Guest
    Default leaking water pump and radweld?
    have a mates Astra which has a bit of a leak, i think from the waterpump.
    Will radweld be suitable fix as a stop gap solution?
    Forum Junkie
    Oct 2003
    Rotterdam
    4,130
    Probably not, nothing can help if it's comming out the shaft seal.
  3. #3
    Dudboy
    Guest
    I don't know where its coming out of, need to remove the damn undertray to see. last time i checked the engine over, it was in the dark with no obvious puddles under the car.
    just made sure it wasn't mixing with the oil.
  4. #4
    Forum User
    Jun 2005
    marlow
    749
    I use k-seal, its alot better than rad weld. Its more expensive but well worth it
    http://www.kalimex.co.uk/section.htm...01.04.&pgid=17
