Volkswagen Driver Magazine
Results 1 to 6 of 6
Thread: Metal coolant hose for AGG 8v engine
    Forum User
    Oct 2003
    982
    Default Metal coolant hose for AGG 8v engine
    Noticed a slight water leak today on dads '96 8v Gti Golf
    The metal water hose that runs on the RHS of the engine, from the bulkhead area down under the main engine harness plug, & then runs in front of the dizzy to the oil cooler area is weeping coolant
    Pic nicked off t'internet:
    Its started leaking just above the gearbox /starter motor area - I think its got a pinhole underneath where it rests on the block/bellhousing
    How much do these cost & anyone think that chopping out the offending area & bridging the gap with a section of rubber hose & jubilees will work?
    Events Team vw_singh's Avatar
    Oct 2003
    6,135
    844
    The hose is pretty cheap from GSF/Euro Car parts. About £10.
    Gurds
    13.7sec @ Santa Pod. Standard ABF
    16v FTW! RWD 6 Cylinder for the daily. Now FWD 6 Cyl
    Click for my build thread http://www.clubgti.com/showthread.ph...-at-Brands-P38
    Quote Originally Posted by Matt82 View Post
    ...SKF, been making bearings since the dawn of time, god probably used them when he was making the universe...
  3. #3
    Forum Junkie i.a.n.b's Avatar
    May 2006
    Banbury
    4,144
    If you can get non gen for £10 do it, £62 from VW these days. Part number if it helps is 037 121 065L.
    2l 8v - 137 bhp. I'm happy
  4. #4
    Forum User
    Oct 2003
    982
    vw singh - on the gsf website all I can see is this:
    179VG0060 METAL WATER PIPE G3 2.0 4.92> (Ch.1HNW400001>) £23.50
    would that be the one?
    Thanks ianb, was going to ask what the part no was! I was expecting a £40 to £45 price but that is shocking!
  5. #5
    Forum User
    Mar 2009
    birmingham
    42
    these all ways start leaking had one go on me on my mk2 gti it went where it teed off ,you could cut the section out and you a piece of hose and jubilee clips both sides ,but it's worth change as it might start to leak else where. .
  6. #6
    Oct 2003
    6,135
    844
    The one I bought was for a mk2 so the mk3 part could cost more I guess? The is only one metal coolant hose on these engines but see if you can pop down your local branch to confirm it.
    Gurds
