HRP
Results 1 to 14 of 14
Thread: Mk2 Golf Steering Column Problem
    Forum User
    Nov 2011
    Airdrie
    88
    Default Mk2 Golf Steering Column Problem
    I've a lot of play in the steering wheel. Removed the wheel and the stalks. Allen screw holding the ignition lock on was tight. Bearing in ignition lock ok. I decided to remove column to replace bearing at bottom of column. Removed allen screw holding ignition lock on and removed clamp bolt on UJ at bottom of column. Tried to pull column out but top half came out leaving bottom half of column in situ. Is this right or have I broken it?
    Car is a 92 mk2 GTI with PAS
    Moderator MUSHY 16V's Avatar
    Jan 2008
    aberdeen
    9,555
    1,104
    i think went about it the wrong way you would have been better to take the whole column out
    but it should still go back together
    take out the two shear bolts that hold the column on with mole grips they wont be tight
    it will make it easy to work on
    did it still have the spring under the adapter
    Remember and check your membership renewal date
    Paid membership only £10 in the club shop now with paypal click here
  3. #3
    Forum User
    Oct 2009
    Dewsbury
    659
    It may be that you have play in the steering rack/lower ball joints/track rod ends. I'd jack the car up and check for play there before stripping the entire column down mate.
  4. #4
    Forum User
    Nov 2011
    Airdrie
    88
    Quote Originally Posted by MUSHY 16V View Post
    Yes, the spring is still there. I put the top of the column back and it slides over the bottom half ok. I've got a new bearing so will try that first. Just hope there's no play in the 2 halfs of the column where they join.
  5. #5
    Forum User
    Nov 2011
    Airdrie
    88
    Should there be a clip of some kind between the 2 halfs of the steering column shaft so the 2 fit snugly together?
    Mk2 GTI 16V, Mk5 R32
  6. #6
    Forum User
    Jun 2009
    320
    39
    Yes there is bud. Its got several little holes in it. its a flat piece of metal. Will see if I can find you a picture. If you rest the metal clip type thing on the flat part of the column and slide the outer part over you will see when it lines up.
    Ive done exactly the same on mine and it seems to go back together ok.
  7. #7
    Forum User
    Nov 2011
    Airdrie
    88
    Quote Originally Posted by Pluginz View Post
    Got my column out finally. Shear bolts were a B to come out. Found clip lying in bottom of column. Joined 2 halfs of column shaft with clip in it's slot. Now tight. Just have the bearing at bottom of column and UJ rubber gaiter to change. thanks.
  8. #8
    Forum User
    Jun 2009
    320
    39
    Ah good man. I never had to remove the shear bolts when I did mine though, the whole column and barrel all slide out the column tube without removing it.
    Hehe top bearing I did change, and for all the effort wasnt worth it.
    Lower bearing is fairly easy to do yes bud. Tap old bearing out from the top half of the column tube with a rachet extension and tap new one in from bottom, 5 minute job
    Your changing the UJ gaitor, nice, hows your downpipe heatshield? Good condition? 8v or 16v?
  9. #9
    Forum User
    Nov 2011
    Airdrie
    88
    I didn't know it had a heatshield. Will need to look, have never noticed one. Got a good used gaiter. Car is 16V. cheers
  10. #10
    Forum User
    Jun 2009
    320
    39
    Ok, well im not too sure on KR, but 8v has a heat shield on downpipe to protect the rubber gaitor from getting melted, just a thought m8 thats all.
  11. #11
    Forum Junkie
    Oct 2003
    London
    1,055
    they rust, then they rattle so folk take them off
  12. #12
    Forum User
    Aug 2011
    98
    I recently had a lot of play in the steering wheel on my mk2 kr. Looked into tightening the lock housing allen bolt but it was tight like yours is.
    The problem with mine was where the bracket that holds the upper end of the column had become loose where it is bolted to the car. Might be worth checking them too? They were quite hight up under the dash and took me a while to spot them as they are pretty hidden behind all the wires.
  13. #13
    Forum User
    Aug 2011
    98
    My heat shield is badly rusted and has a noisy/rattly jubilee around it.
    Is it ok to remove it or am I gonna melt the UJ gaiter?
  14. #14
    Forum User
    Nov 2011
    Airdrie
    88
    No more play in my column after replacing the bottom bearing and the clip between 2 halfs of column shaft. Found one of my track rod gaiters burst so will renew the track rod ends while I'm in there. I also covered my 'new' UJ gaiter in heat resistant fibre/alu cloth as the heat shield was missing.
