HRP
Results 1 to 23 of 23
Thread: Rear wheel arch rust
    Forum Junkie muppet9966's Avatar
    Apr 2005
    Uxbridge, United Kingdom
    1,843
    Default Rear wheel arch rust
    Looks like a bad day for me.
    Just turned up at work after a nice relaxing drive to work, opened the boot to remove my laptop bag and spotted this:
    Drivers side.
    MOT isnt due til Dec/Jan but I need to sort this out asap - looks dangerous.
    I've had parts of the wheel arch welded for prevous MOTs.
    Does anyone know how to go about fixing this (and maybe a rough cost).
    I'm not sure if mobile welders are the way to go where I can remove most of the bits (maybe fuel tank), or just let a garage sort it out.
    Anyone have a decent garage in NW London?
    Thanks in advance.
    1988 EZ 1.6 Jade Green Golf CL, with 15" BBS RA alloys, Weber Carb & GTI exhaust
    Events Team
    Nov 2010
    1,670
    259
    Quote Originally Posted by muppet9966 View Post
    Drivers side.
    Thanks in advance.
    That doesn't look too bad to me. Best bet would be to strip boot and get a wire brush to it and see where it takes you. Then if it's just surface rust put some rust treatment on, prime, paint. Job done
    I know a great welder in South East London. He welded my floor pan on my MK2, it was such a good job you wouldn't notice I did ask him to weld both sides of floor pan. He's in Chelsfield, Kent so about 5 mins away off juntion 4 off the M25.
  3. #3
    Apr 2005
    1,843
    Cheers for you input Chris.
    It isnt just surface rust as i can see through
    I do have a local garage, but I want to get some quotes.
  4. #4
    Events Team
    Nov 2010
    1,670
    259
    In that case you might have to have the rust cut out and a plate welded in. I probably reckon about £200, bearing in mind I only paid £100 for the rear section of my floor pan to have a patch welded in.
  5. #5
    Apr 2005
    1,843
    Oh god, thats what I was fearing.
    Thanks.
    As its close to the fuel tank, I'm assuming that will need to be moved/come out.
  6. #6
    Events Team
    Nov 2010
    1,670
    259
    Thanks.
    Yes fuel tank might need removing. It's not a hard job at all, I just hope you don't find to much rust behind the fillar cap as that's a common problem for them to rust from behind and cause lots of nasty issues. Fingers crossed that's ok. It's all the mud and old salt from the roads that causes this!!
  7. #7
    Apr 2005
    1,843
    Yeah, thats why I had to have some welding done around that same arch afew years ago for the MOT.
    Fingers crossed.
    I may look into mobile welders......
  8. #8
    Apr 2005
    1,843
    Looks like its worse than I thought:
    Looks like the turret has completely come away from the chasis.
    Just got a quote from a local garage at work, welding all around the turret for approx £200
  9. #9
    Forum Junkie
    Oct 2003
    Scotland, Aberdeen
    10,455
    Thats prety fecked.
    You'll find a ton more problems when you really get under the arch and strip the underseal away......
  10. #10
    Apr 2005
    1,843
    Yeah I know.
    But this garage (who I highly recommend) said its do-able and they will weld a thick plate around the turret for added strength.
    As this is my baby, I will probably get it done.
  11. #11
    Paid Member Richard Mk2's Avatar
    Apr 2007
    West London & Herts
    12,108
    1,362
    Doesn't look too bad mate. But as Andy said, there might be some more rust hidden away.
    Hopefully not as i love this mk2
    Hope you get it sorted mate
  12. #12
    Forum Junkie
    Oct 2003
    cambridge , uk
    13,513
    get a price to have it all cut out and pieces welded in , not a mot weld up where they weld a plate over whats there
    big differance in how it will last
    91 G60 ed1 , 89 16v gti , 88 breadvan
  13. #13
    Moderator rubjonny's Avatar
    Oct 2003
    41,899
    188
    to get that fixed properly is going to take serious effort. seems someone has been there before and tried to fix it, but failed to do the job right and so rust cas carried on its merry way.
    looking at it the rust seems to be the inner arch rather than the turret, so you might get away with cutting out part of the inner and welding a new panel in. not an easy job especially without damaging the outer.
    as andy says you'll probably find a lot more rot when you start digging! i advise you take both outer plastic trims off and really look under there, look all up around the filler cap and underneath. looking at it you'll probably find its too far gone to economically fix
    VAG Documents & Downloads
  14. #14
    CGTI Regional Host - Birmingham & Midlands nut 20v's Avatar
    Oct 2011
    Overtaking you
    1,566
    332
    ive just done inner and outer arches fuel cap and tank bracket not a small job and a lot of mess inside and out side the car and took a long time. looks like to get full acess you might have to remove the rear quater and then when you start poking around you will definatley find more also there is prep there is so much underseal there it all has to come off first then that WILL definatley reveal more also when you get it all prepped and panels in place ready to weld it has to be clean that means all the wax from inside the panels as this melts and flows down into the weld and then it blows big holes in the panel so who ever does this is taking on a big job you could patch over and fill with seam sealant and paint over it would be enough to pass mot but would not last long so what i think it will come down to is how much you love the car!
  15. #15
    Apr 2005
    1,843
    Cheers for the input guys.
    I had this arch welded afew years ago for the MOT, this was a plate welded on the arch and sealed.
    That explains some of the black sealant.
    Ive been quoted by this garage to cut out the rust and weld plates to the arch/turret, this includes removing the fuel tank and filler and poking around.
    I've been quoted 3/4 hours, but I suspect this may increase.
    As this car has been in my family since 1990 and was passed to me in 2005, I will be getting this work done.
    I know it probably wont be economically to fix this car, but then it is a 24 year old, and means alot to me.
    I may look to get the fuel tank bracket as this will probably be shot aswell (anyone got the part number?)
    Thanks again guys.
  16. #16
    Oct 2003
    41,899
    188
    191803483, 5.21+VAT from vw
  17. #17
    Apr 2005
    1,843
    Cheers John, VW Citygate dont stock that part, so I've ordered from TPS.
    Car is in garage (looks in a bad way) but I'm getting it repaired (properly) and it will take some time
  18. #18
    Forum Junkie Mike_H's Avatar
    Oct 2004
    19,736
    24
    I know a really good welder fabricator, who's very reasonable on price, if you haven't already decided on someone to do this.
    Megasquirt for the win!! Long Johns for the Win-(ter Mechanic!)
  19. #19
    Apr 2005
    1,843
    Cheers Mike,
    I'm having this done by the local work garage, guys seems to know his stuff.
    I popped by yesterday and he cut most, if not all, the rust out, pretty scary stuff as it could have given way anytime soon. Especially with the poor condition our roads are in.
  20. #20
    Apr 2005
    1,843
    Well hey guys,
    I thought i would update on this rust issue I found on my car.
    The golf has been to be garage and I've had it back about 1 1/2 weeks now.
    I managed to check out the damage after the garage cut out all the rust, although I didnt take any pictures.
    Here are the results, I'm pretty pleased with it.
    It was welded both sides, new filler bracket and I'm going to replace the fuel tank straps once VW Heritage have them in stock.
    I would definitely recommend this garage, based in Hemel Hempstead, CarSpek.
  21. #21
    Oct 2004
    19,736
    24
    Looks ok for MOT welding, but not really top quality work. How much did it cost you?
    Fella I know just made this panel for a mate of mine.... it's the same guy who did Mike Thurston's and Jommanjo's roll cages.
  22. #22
    Apr 2005
    1,843
    It was £230 with all the rust was cut away, with plates welded on both sides, and then coated, all around the turret.
    I shat myself afew times as when you pushed on the suspension, the arch slowly came away from the body.
    That panel looks great.
  23. #23
    Oct 2004
    19,736
    24
    Definitely needed fixing, and sounds like a fair price for the work done. I guess what's needed and how much you'd pay, depends on how you see the car.
