Results 1 to 16 of 16
Thread: Race driveshafts, VR6
    Forum Junkie RobT's Avatar
    Oct 2003
    Cheshire
    5,224
    465
    Default Race driveshafts, VR6
    Hi
    i am in the process of buying some race spec driveshafts, mk3/corrado vr6 spec, twistable steel and very very strong (as used on numerous big power rallycross cars).
    £500 a pair for bare shafts with no CVs if anyone is interested, will order end of this week, say Sat 13th. Coming from abroad so easy to ship multiple sets if anyone else wants some.
    Rob
    Forum Junkie 3hirty8ight's Avatar
    Oct 2005
    1,900
    166
    Surely having a slightly weaker link in the drivetrain such as a driveshaft is better than ruining a super expensive box? Just a thought, I'm all for super nice driveshafts :-)
    What CV's are you going to run! GKN Motorsports stuff?
    Mk2 16v MSVR Racer No. 38
    Aka 'Herry Wright'
  3. #3
    Oct 2003
    Cheshire
    5,224
    465
    The tyre is the weakpoint if the whole system is designed sufficiently. Std pattern cvs.
  4. #4
    Oct 2005
    1,900
    166
    £500 shafts with standard CV joints!?
    Wouldn't waste your time or money... There's plenty of serious cars using standard driveshafts with FAR More torque going through them than any 16v n/a could ever produce?
    Spike loading such and bumps and curbs will cause failure in the splined area if they are previously damaged.. But I'm never seen an actual shaft fail? - not before the CV joint fell into a billion pieces before hand!
    However this is my opinion, based on experience and what is known already..
    They'll look nice though :-)
    Aka 'Herry Wright'
  5. #5
    Oct 2003
    Cheshire
    5,224
    465
    This thread is about offering folks the option - I am buying some not only for strength reasons, but for clearance on the offside chassis leg, and lightness (as they are drilled).
    And i didn't say std CVs. I said std 'pattern' CVs But you wont be interested in those details, as it sounds like you know it all already.
  6. #6
    Oct 2005
    1,900
    166
    Crack on Batman, sorry for the hijack!
    Aka 'Herry Wright'
  7. #7
    Oct 2003
    Cheshire
    5,224
    465
    Wonder why the vr6 vento racers had gemini driveshafts....
  8. #8
    Oct 2005
    1,900
    166
    Probably due to all the snapped shafts they were experiencing. (Slight hint of sarcasm).
    They also had:
    Inner CV joints in EN19 nitrided steel cages and 300M steel
    The CV joints were the weak link. specifically the inners, which most Golf Gti championship competitors can relate too nowadays.
    Your post above state "std pattern CV's" - Which to me sounded like std items. Silly me!
    Aka 'Herry Wright'
  9. #9
    Oct 2003
    Cheshire
    5,224
    465
    Enough said.
  10. #10
    Forum Junkie
    Nov 2008
    London
    2,527
    How much lighter, and is it possible to have shafts specced to reduce torque steer or is that simply down to their (differing) lengths?
  11. #11
    Forum Junkie
    Jun 2005
    Wales
    1,190
    had major problem with drive shafts cvs exploding, 2 per trackday , and i mean exploding to pieces, was seriously p i ssing me off, kinda worked it out due to the rag top weight ,high speed cornering and clipping kerb at the same , drive shaft was fowling on the chassie leg on full lean , .. heated chassie leggs with map gas to cherry red and re shaped with hammer , problem fixed , was chuffed ,
  12. #12
    Oct 2003
    Cheshire
    5,224
    465
    Good idea paul, but not allowed to alter the floorpan in hillclimb regs, even though i know plenty of people do.....
    Dont know precisely howmuch lighter they are than std shafts, so will report that when mine arrive. They wont change torque steer i dont think.
  13. #13
    Forum Junkie
    Jun 2005
    Wales
    1,190
    Quote Originally Posted by RobT View Post
    noticed a lot of the proper race mk1 s cut and notch and plate the chassie legg tidy , would that be breatching rules rob , or is it just in hill climbing regs . , plenty of mk1 s in hill climbing though .
    i think any rotational weight saving helps, , good luck hope they improove
  14. #14
    Oct 2003
    Cheshire
    5,224
    465
    Hillclimbing modified production rules state the Unibody must not be altered between the wheel centers, so notching the chassus rails for clearance should not take place. This of course limits ride height.
  15. #15
    Forum Junkie
    Jun 2005
    Wales
    1,190
    must be a few people out ther cheating then rob ,
  16. #16
    Oct 2003
    Cheshire
    5,224
    465
    Oh yes. Lots. I've seen transmission tunnels chopped. Big sections of floor removed. Chassis rails notched. You name it. But if nobody officially complains, then it didnt happen.
    Thats racing for ya!
