Volkswagen Driver Magazine
Results 1 to 7 of 7
Thread: Mk2 turbo.
    Forum User benjifou666's Avatar
    Feb 2013
    newtown, mid wales
    20
    Default Mk2 turbo.
    Right. Found a digivant engine with a turbo kit fitted. Minus the intercooler and downpipe. Would the td parts fit? Also what about engine management? Will it run on the standard ecu?
    Mk5 dirty derv
    Mk2 Gti 8v barn find
    CGTI Committee - Club Secretary Crispy 8V's Avatar
    Oct 2003
    NW
    10,219
    113
    any intercooler could fit, depends on the pipe work that comes with it, down pipe the same may do or bit of fab to get it in
    managment harder, I just don't know K'jet yes with little mods, does it come with wiring? theres load of options with that one if OEM does't work with little fettleing
    CGTI Member #4026 Mk 1 TDI, Mk 1 1.6 GTI, Mk 4
  3. #3
    Feb 2013
    newtown, mid wales
    20
    Apparently the sprinter cooler fits a champ. Ill do the piping template out of cardboard tube, then find nessecery lengths and connections to suit. Thers no wireing with it. Wiuld the oem ecu work with a remap to allow for different fueling? Also what would i do with the maf sensor?
    Mk5 dirty derv
  4. #4
    CGTI Regional Host - Birmingham & Midlands nut 20v's Avatar
    Oct 2011
    Overtaking you
    1,566
    331
    Sprinter ones are plastic ends large and thin i have one in my T4 and im not happy with it The toyo aluminum ones on ebay are well made i have 2 of these very happy with them.
  5. #5
    Forum User
    Oct 2010
    Basingstoke Hampshire
    45
    I raye the toyo ones aswell i habe used them on a few 20 v conversions altho just been given a cosworth intercooler im gonna use next
    They call me oem
  6. #6
    Forum Junkie
    Nov 2008
    London
    2,527
    If it's digifant you could try and run a g60 ecu.
  7. #7
    Forum User
    Nov 2005
    287
    G60 digi1 management will work if you get a turbo eprom chip.
    8v GTi Digi2 won't work.
