Results 1 to 5 of 5
Thread: Auto test handling with LSD
    Forum User
    Dec 2003
    Australia
    441
    Default Auto test handling with LSD
    Hi Guys and Gals,
    Wondering if anyone has experience with autotest/motorkhana?
    I'm seriously considering putting in a Quaife LSD but am wondering how it will effect the low speed handling?
    Any help or advice would be great.
    Golfs, a rare and elusive species in Australia. Flog racing.
    Forum Junkie
    Nov 2003
    Abz
    5,220
    1,027
    Have you considered a Wavetrac LSD instead ... reportedly an improvement over the Quaife.
    Not done autotesting but in hillclimbing / sprinting a Mk1 & Mk2 Golf GTI ... the low speed handling / grip is good (never ran them without to compare), torque steer is acceptable. What positive caster can you run ?
    Have run a Mk1 on track with and without a Quaife ... handling under power out of the slow corners is so much better `with`.
    Hope that helps.
  3. #3
    Forum User
    Dec 2003
    Australia
    441
    Yes either a wavetrack or a quaife would be acceptable, I just wonder if either will cause massive low speed turning issues.
    Example doing a super tight turn around a witches hat.
  4. #4
    CGTI Committee
    Sep 2006
    419
    47
    i've got a wavetrac... but a proper plate dif is what you need
  5. #5
    Paid Member pascal77uk's Avatar
    Jul 2006
    Glos
    3,975
    170
    Gripper are who you need to speak to.
