Auto test handling with LSD
Discussion in 'Track Prep & Tech' started by ausgolfer, Sep 29, 2013.
  1. ausgolfer Forum Member
    Australia
    Hi Guys and Gals,
    Wondering if anyone has experience with autotest/motorkhana?
    I'm seriously considering putting in a Quaife LSD but am wondering how it will effect the low speed handling?
    Any help or advice would be great.
  2. jamesa Forum Junkie
    Abz
    Have you considered a Wavetrac LSD instead ... reportedly an improvement over the Quaife.
    Not done autotesting but in hillclimbing / sprinting a Mk1 & Mk2 Golf GTI ... the low speed handling / grip is good (never ran them without to compare), torque steer is acceptable. What positive caster can you run ?
    Have run a Mk1 on track with and without a Quaife ... handling under power out of the slow corners is so much better `with`.
    Hope that helps.
  3. ausgolfer Forum Member
    Australia
    Yes either a wavetrack or a quaife would be acceptable, I just wonder if either will cause massive low speed turning issues.
    Example doing a super tight turn around a witches hat.
  4. taks CGTI Committee Paid Member
    i've got a wavetrac... but a proper plate dif is what you need
  5. pascal77uk Paid Member Paid Member
    Chelt
    Gripper are who you need to speak to.
