I needed a car that can be a development mule for our ECUs. I had planned to use my Mk2 Golf, but that would require a lot of non-standard items for things like electronic pedal control, traction control, launch control and turbo anti lag. I also want to race the car, but the Golf has a Corrado/Passat 9A block in, which means it would have to compete in the libre class. It would never be competitive in that class. Then this advert caught my eye. I know the car quite well, having watch Sam develop it after buying it from Dan. I'd also driven it at Curborough once for a lap or two. It went really well. It was also the ideal base for what I need, as we already support the VAG drive by wire system, it has wheel speed sensors and the 20v engine is well developed. The suspension will hopefully mean I can develop the car in to a competitive car in the Mod Prod class at club level. From the for sale ad: It sports a very special Seat Supercopa race tag sealed Ricardo Gearbox with very few miles sporting uprated internals, steel selector forks and most importantly Ricardo plated diff! Awesome piece of kit! Brand new Helix 5 paddle clutch kit ! Fully MOT-ed so road legal FULL SPEC Year 2000 A3 Quattro shell fully stripped out with : Full multi point welded cage Sparco Evo Bucket seats Sabelt 4" harnesses ENGINE 1.8T ARZ Low milage engine ME7.5 de immo management custom mapped by ADE Tuning K03s turbo with ported exhaust housing/wastegate Manifold ported and matched to head and turbo 3" Pipewerx full exhaust from turbo to the end sounds awesome 2.5" boost pipes ABD Race TIP and cone filter FMIC Uprated stiffer engine, g.box mounts and dog bone CHASSIS KONI/FK Stainless coilovers height and damping adjustable Compbrake solid top mounts R32 quick rack 2.2 turns lock to lock R32 cast wishbones correcting angle to eliminate bump stear R32 hubs H&R adjustable ARB-s front and rear Forge adjustable rear lower camber correcting adjustable arms 4 wheel full computer alingment at main dealer with printout BRAKES Seat Sport AP 4 pot calipers 312mm discs Hawk pads 256mm vented rears with big Ally calipers ABS retained WHEELS Very rare Seat Supercoppa 8x18" OZ racing lightweight wheels that clear any caliper known to man! Dan's orignal build thread is here: http://www.edition38.com/forums/index.php?showtopic=52032&hl=
Since I bought the car, I've replaced the seat belt on the drivers side as the crotch strap was missing. I've not driven it, and when I tried to start it the other day, the battery was flat. It's going to be a bit of a slow burner for now, but I hope to make decent progress over the winter. Plans First thing I need to do is get the car to a race event for a scrutineer to look it over. It will need some work to get it race legal, but I want to make sure I know exactly what's needed. Then I'll replace the OEM ECU with an S80 and an STC, our electronic throttle controller. A new engine wiring loom will go in as well, and possibly an XDash to replace the standard dash allowing me to remove the dashboard entirely. Then the car will go on a diet. I'll strip out electric windows, excess wiring, add perspex windows. The engine will run full sequential injection and ignition, as well as VVT, all controlled by the S80. THe oreder in which this will happen is flexible, but the most important thing is to make the car race legal in order to compete from the beginning of the year.
Has all the interior gone? you would be better trying to get in road modified than modprod.....over 2L modprod has some VERY fast cars in it
No idea what's left, I still need to make a trip to Sam's to collect parts. I doubt any of the interior will be there, but it should be fairly easy to get hold of if needed. I'll chat to the scrutineer when I take it to get it looked at.
Everyone knows A3's make the best track cars! As I keep telling everyone, it's the next generations mk2 golf!
I'd tried to take the car out the garage the other day to take some pictures, and start making a to do list, but the battery was flat. So I took it out to charge it. 3 weeks later, and I put it in the car this morning, and fired it up. However, there was no time for pictures, as I put it straight on the trailer and took it up to Curborough, as the Shenstone And District Car Club were having a sprint day today. This mean there would be scrutineers in attendance, who would (I was told) be happy to look over the car, and let me know what would be needed to compete next year, and what class I would be in. As expected, they were very friendly and helpful. However, I was a bit worried, as I fully expected a list the length of my arm before I could compete. Andy Benfield had a look over the car. Due to the level of prep, I'm straight in to Modified Production cars over 2000cc. I could try to get the car in to Road Going Modified, but it's unlikely I would be able to refit enough of the trim to do so. As I don't really care for now, as I just want to get racing, ModProd will do. After a good look around the car, Andy only required two items to be changed. I need to change the steering wheel as it still has the airbag in, and I need to tidy up a bit of the wiring in the engine bay. That's it!! I'm delighted. I can now start making plans for what I want to do to the car, and know what I can't do (not much) and what I can do (pretty much anything). One minor issue is that I'm in the over 2000cc class. This means I may not be allowed a Nat B Non Race license, and might have to apply for a Nat A Race License. This is more expensive, and requires a full day course, but it will also be needed if I decide to compete in the Classic VW Challenge with the Golf. I now need to decide how to do the wiring. I'm replacing the ECU with an S80, and using an STC to control the DBW system. I have two choices with the wiring: Strip out as much as I can, but leave enough to operate the lights etc, so that I can keep it road legal and drive to the events Rip everything out, and go full race harness with only the bits I need. I have the tools and wire to do this, but then I will have to buy a trailer, as the one I borrow at the moment is right at the limit size wise for this car. To Do Replace front seat mounts. Too high and too far back for me Change the seat. I prefer the ones in the Golf, and have two, so will put one in this Replace steering wheel Remove dash, and investigate wiring Buy race gear, including HANS device and helmet.
Great News !! I have no interior of any sort but it seems that now you do not need it any more? I do still have spare bumpers, pair of doors, (drivers side already lightened), bonnet, prop shaft But, as the fate has it i have just bought an 1.6 A3 of ebay with slight engine fault so if you need any bits i can help I keep looking at my Abf with Jenveys every time i go in my garage and keep meaning to find a home for it, so this came up cheap so i decided to get it A3 with Abf on Itb-s in it will not set world on fire, but it will do for occasional track day i guess
Thanks Sam. I need to make a plan and collect the parts from you soon. I'll check the diary and get back to you. Don't worry about interior parts, I'm just going in to Mod Prod. I have no illusions about being competitive to start with, so it doesn't matter what class I'm in.
As promised, a quiet start. However, these have now arrived: OMP Uno 320 with two momentary switches, Momo boss and Driftworks quick release system. My wife is away this weekend, so I have the girls to myself. Hopefully I'll still find time to fit them.
I fitted the steering wheel at the weekend, and also moved some stuff around so I could give my neighbour his garage back. I also realised I can move the driver's seat forward, so that I'll be able to reach the pedals more easily. I forgot to take pictures. This is a common occurrence.
Picture of the steering wheel fitted: I swapped the seats out this morning, and tried moving the seat all the way forward, all the way back, and in the central option. The central setting was most comfortable. Old seats: New seat. Er, forgot to take a picture of the seat fitted. It's the passenger seat from the Golf. Looking at the amount of wiring in the car, I'm going to go for a custom race loom, and just remove the entire OEM loom. I have most of the connectors I need new, and should be able to get most of the ones I don't have. I will only have the following wired in: Complete engine loom Fuel pumps Windscreen wipers Brake lights for track day testing Electronic dash I'll get a simple dash plate made up, with power, ignition and the wiper switches, as well as the switches needed for the ECU. I can always add more switches/panels as required. I've found a Greek supplier of plastic windows for the car, who is a lot cheaper than here. I've also ordered an exhaust manifold from Bill. It will be ceramic coated with 4 EGT sensor bungs. Next weekend I need to measure up for the engine loom, and decide where to mount the ECU. I need to also order a small race battery and get that mounted, so I can sort the interior wiring loom.
I did some more work to this today. First I needed to take some measurements for the suspension. I also want to see what was on there, but struggled with getting pictures. I know that the car as it stands is too low. When measuring today, the front arms were level at full extension, so the car needs to be raised a good inch or more. Longer term plans include either changing the spindles, or use some sort of spacer to move the ball joint down. Both will need the bump steer sorting. Does anyone know if the TT-RS hubs fit this chassis? From RobT's thread: I also checked the spare gearbox code, it's an FHB. Then I moved on to the interior. First up, out with the dash. This needs to go, and also means I can see just how much wiring there actually is. I then started working through the wiring to see what's there, and how to remove it. I started at the back of the car, as all I want to keep there are the brake lights, fuel pump power and fuel level sender. The rear wheel speed sensors enter the car through the rear arches: I then worked through all the wires, central locking pipes and also the rear washer pipe. I've removed all the wiring from the tail gate, as well as the central locking pipes. The CL pump from the rear is also gone. I need to strip all the loom tape off the looms as I go, so I can leave the wiring that I want to keep in place. It's not much, but it will make it much easier to just leave it in place. If anyone has any fuse box schematics with what all the plugs and relays are, much like RubJonny's awesome Mk2 Fusebox FAQ, that would be really helpful. I have to keep the car able to move under it's own power, so I can move it around, and get it on the trailer when the wiring is done.
Thanks Mushy, I'll have a look. I spent a few hours this morning on removing the interior loom. Everything from the steering wheel to the tail lights is now either detached or I need it attached. I'm a lot further along than I thought I'd be at this point. Here's what it looks like: The loom running down the passenger side floor is completely detached apart from the rear wheel speed sensor. Unfortunately, this appears to be magnetic, not hall effect. If this is the case, I'm going to have to either replace them, or use a converter to change the signal to a square wave. The loom running along the roof, including the alarm wiring, is completely detached, and in the footwell. The driver side still has the wheel speed sensor, fuel pump and fuel level sender wiring all attached. I've stripped the loom out the passenger door, and most of the driver's side door is loose, ready to be removed. Next up, the engine bay loom, including lights and engine. I don't need any front lights, so that will all come out. I then need to work out what I can remove from the engine. All I need is for it to start, so the fans can be disconnected as well.
