What car are these from
Discussion in 'Wheels and Tyres' started by skydivebaz, Jun 27, 2016.
  1. skydivebaz
    skydivebaz Forum Member
    Black Isle, Ross-Shire
    I spotted them on ebay, look like vr6 15s but these are BBS 442 ET33. I thought the vr6 were more like 42-43 ??? The spokes do look like they are set further back in the dish.
    Sent from my SM-G900F using Tapatalk
  2. skydivebaz
    Anyone??
  3. notenoughtime
    Essex
  4. Toyotec
    Those are from a MK3 VR6 like my old car...
  5. notenoughtime
    Essex
    Eddie look at where the spokes are its slightly deeper on the ones baz has found
  6. MUSHY 16V
    aberdeen
    sure passat's have one's that are 35 or 38 et
  7. Toyotec
    Might be the picture Cary.
    Looks just like the ones I have out in the back.
  8. MUSHY 16V
    aberdeen
    the vw part number is for golf ones is 1H0601025AA fitted to gti 16v and vr6
    15" 6.5" et43
  9. skydivebaz
    These are et 33 ?? BBS 442.
  10. Toyotec
    I must admit I did skim read that.
    The design does look like the original wheels from a MK3 VR6, but as Justin pointing out, mine has different specs and offsets to your picture.
    In addition there is a step on the outer edge of the rim not present on the items that were on my car.
    Can you find any part number for the rim?
  11. skydivebaz
    I only spotted them as I was looking for a set of VR6 wheels for my mk2 so I could run 288 brakes. I have the early VR6 wheels on that I think look almost period for the mk2.
  12. skydivebaz
    The ET of 33 would be ok for the mk2 though although the price he wants I would want them attached to a car!!! And also would they actually accommodate the 288mm brakes.
  13. skydivebaz
    Passat aftermarket? ? They are a bbs wheel but not VW marked.
  14. Toyotec
    Looks so.
  15. skydivebaz
    Well I waited and waited on the listing being constantly relished and struck a deal and bought them. So wait and see if they turn up! !! I guess they are passat aftermarket BBS 442 but at ET33 they will be perfect on the mk2
  16. StuMc
    50? 20` 47 N - 06? 57` 57 E
    They might not cover 288s at ET33...
    I bought some wheels for my VR6 at a local wheel specialist, where you select the size and style of wheel and they fit them for you (supposedly in the correct ET...). They fitted fine, until I came to change the pads about 6 months later; they wouldn't fit back on with fresh pads. Turns out they were GTI offset of ET35 vs the correct VR offset of ET43... [:x]
  17. Toyotec
    Good point actually.
  18. skydivebaz
    On the tuv approval for them it does quote all the mk3 models and high kw engines so I think they should. And typical a set appear on Gumtree in Scotland for 120 !!!
  19. skydivebaz
    My only guess is bbs made them as an option for vw to sell aftermarket from the production models.
  20. skydivebaz
    Currently have early vr6 wheels fitted but my god they are a pain to clean. But love them in sparkle silver
