Tyres for my RS reps
Discussion in 'Wheels and Tyres' started by Savagesam, Sep 28, 2016.
  1. Savagesam
    I've got some RS reps coming. They are 16x7 - whatever the 7 means.
    I'm running standard height at the moment but it will probably go to most likely 20-30mm lower.
    What tyre size would you run? 195/40?50?
    And what tyres Toyo Proxes TR-1 seem to be in my budget, of about 50 a corner. What else?
  2. mr.brown
    Sunny Surrey
    195/45/16 will be fine on a 7" wide rim. Assuming road use I've been buying Uniroyal Rainsports for the last couple of years - been very happy with them especially, as the name suggests, in the wet.
  3. Savagesam
    I've goT them on my current wheels and they are fantastic but they are a bit pricey in this size :(
    I was looking at the wrong size 45 a corner, look what I'm ordering [:D]
  4. Savagesam
    Also, will they clear my 288 brakes?
    And another, I'll I have any stretch with 195/45
  5. Break Forum Member
    i have used both on my golf in the same sizes, would recommend either.
    i dont think you will have any stretch at all on a 7'' wide rim using 195/45/16
  6. Savagesam
    Thank god for that, I don't like it.
    Awesome. I'll order them now [:D]
  7. K7aus
    K7aus Paid Member Paid Member
    lancashire / Gloucester
    16" clear 312mm brakes on my mk4 gt tdi
    But you may need a spacer, dependent on offset and wheel design.
  8. Savagesam
    I forgot they were 16's so that won't be an issue.
    Lets hope i won't!
  9. SimonG Forum Member
    Northamptonshire
    You'll have an ever so slight stretch with the tyres in that size on that width of rim but really it's negligible and hardly noticeable. I have this size tyre currently on my RS722 rims on my Mk3.
