Identifying 1.8t Engine Serial Number
Discussion in '1.8 & 1.8T' started by J66KE B, Oct 13, 2016.
  1. J66KE B Forum Member
    Hi all,
    My car has had an engine transplant many years ago by a previous owner. I've just insured it however I have to declare all mods and they want me to be super detailed..
    I know the engine is an APX from a TT 225, however the insurer wants to know the year of car this came out of, so I guess the only way I can do this is look for the engine serial number and give VW a call?
    Only issue is that I can't find it anywhere, I know it's usually printed on a sticker on the cambelt cover however this is not present. Any ideas?
    Also need the gearbox serial number - It's an 02A from a Mk4 GTI and that's all i know!
    Thanks
  2. MUSHY 16V
    aberdeen
    The engine number is stamped where the engine meets the gearbox
    If you get it one of us with etka can give you a year
    I could do it or John and Eddie also
  3. Toyotec
    APX is a 2000 MY engine as fitted to the TT only. Not sure why the insurance wants to know more than this.
    Gearbox code usual place here
  4. J66KE B Forum Member
    Thank you Mushy as soon as I get hold of it I'll be sure to give you a shout
  5. J66KE B Forum Member
    Nor me but we all know how slippery they can be so just trying to be as thorough as possible. Thanks for the reassurance, I had to complete the form by yesterday and I'd put down the donor model year as 2000.
    Looking at the gearbox diagram you've posted; is that the serial number of the box? So this number is completely different to the gearbox code (eg. 02A)?
    Thanks
  6. MUSHY 16V
    aberdeen
    02A is just the type of gearbox the picture above is the code and number
    Ie AYG is the code and the number after it is the manufacture number it's the same as a engine number if you like
    etka it give you a range of for when they are used so you should be able to get it to a year and month or between certain dates
  7. Fury Phil Paid Member Paid Member
    Dalgety Bay
    I am also trying to identify my serial so that I can update my V5C. I bought the engine new and I have a little bag with stickers in (see photo). Would I be correct in thinking my engine number is BAM058377?
  8. notenoughtime
    Hi Phil
    BAM is the engine code
    058377 will be the engine number
    Fury Phil likes this.
  9. Fury Phil Paid Member Paid Member
    Dalgety Bay
    Thanks Carey
  10. Fury Phil Paid Member Paid Member
    Dalgety Bay
    I realised that BAM was the engine code but a bloke at Skoda told me the engine number was nine digits...
