TT hubs & wish bones on a MK2 Golf
Discussion in 'Track Prep & Tech' started by mayor west, Jul 20, 2017.
  1. RobT
    RobT Forum Junkie
    Cheshire
    ttrs is the ultimate....
  2. Toyotec
    I take it, they also bolt up to a Mk2 X member?
  3. mayor west Forum Member
    MK2 TT are completely different so won't fit the MK2 Golf
    Toyotec likes this.
  4. Toyotec
    This one.
    18836012_10158656237150212_2704367776650470692_n.jpg 18670742_10154531458065496_2790646050289510676_n.jpg [:D]
  5. mayor west Forum Member
    Finally got round to fitting the TT rack. Not as straightforward as I hoped but also not a major task.
    I let my mate do it, mainly for the superior skills he has but also as he wouldn't mind chopping my car up as much as I would. lol
    He didn't take as many pictures of the job as I had hoped though but the main parts were captured.
    The TT mounting points are much wider than the Golf so drastic action was required.
    Once mounted to the subframe it was the task of checking how it would fit through the bulk head & marry up to the column. This took quite a bit of trial fitting & cutting bit by bit.
    The bulkhead had to be cut quite a lot in the end as the angles were so different from rack to rack. The good part was that the TT rack & Golf column were a perfect size match, he just had to shorten the steering knuckle and re-drill it as it was too long. (This wasn't pictured)
    The I had the TT steering arms turned down from M16 to M14 to match the rod ends I had drilled the hubs for.
    These were too long to get any kind of drive-able alignment so we shopped about 15mm off of them.
    Next up was the PAS pipes as these are also different, luckily I had a MK4 Golf TDI in the yard for spares and we managed to get these to fit pretty well with minimal effort.
    We modified the MK4 6 speed PAS / starter mounting bracket and this fitted perfectly when mounting it to a gearbox bolt.
    Then we needed to mount the MK4 fluid res which was also pretty easy and look quite neat I think.
    That's about all I have pictures wise, we set the car up by eye and it seems to drive very nice with a noticeable difference to the steering. IIRC I have 0.7 less turns from lock to lock now.
    Iv'e booked the car in the the alignment doing properly before I can really test it though.
  6. kai_ New Member
    Is it posible to use mk4 subframe? Or mk4 subframe completely different and it's impossible to do?
  7. MUSHY 16V
    aberdeen
    mk4 sub frame has different mounting points to the mk2
  8. Tristan
    Any news on this? Fantastic mods.
  9. Desertstorm
    Desertstorm Paid Member Paid Member
    Toyotec and sparrow like this.
  10. Toyotec
    Looks like you will have another interesting car come Curby on the 28th of May!
  11. Desertstorm
    Hopefully be all sorted by then. Not as loud or probably as quick as the A4 but it should go around the twisty bits a bit quicker. Only 275bhp so 100bhp and 250Lb/ft down on the A4 but probably about 500Kg lighter.
  12. Toyotec
    Look forward to seeing it on the 28th of May!
    Link for the next Curby included here
  13. Romka Forum Member
    mayor west, What is the part number for the coilovers you used and the TT style adaptor?
  14. Jja081196 New Member
    This is an interesting thread! Those coil overs are epic too!
    Does anyone know if the suspension geometry between the mk2 and Mk3 golfs are much different and if this upgrade would be beneficial to a Mk3 Golf? Mostly concerning the shock tower locations and caster adjustment?
    Thanks!
  15. charlyss New Member
    hello, I am interested in doing this in a seat ibiza 6k, I am looking for a wider road, is the tt mk1 route possible in the ibiza 6k? Is it a good improvement in behavior?
  16. Martti Hoop Paid Member Paid Member
    Great thread mayor west!
    Is it possible to use mk4 shocks and spings with the TT hubs on a mk2?
  17. Savagesam
    The top mount locations are different to believe, they need different the turret moving form what I’ve read.
  18. TomAKL
    TomAKL Paid Member Paid Member
    Norf Devon
    Dragging up an old thread up i'm afraid, but i'm curious to trying the TT wishbones on a Mk3 GTI - however i'm wondering what is stopping me using Mk3 late-GTI/VR6 hubs?
    Do the TT balljoints have a different taper to the late Mk3 GTI balljoints?
    I've not bought one of each to compare yet, but hoping someone has previously and can warn me if so! Thanks
