Carriers and callipers
Discussion in 'Mk2' started by L33mox, Sep 23, 2017.
  1. L33mox
    L33mox Paid Member Paid Member
    Hi , I've got 16v hubs with 256mm carriers will g60 callipers work or do I need 280 carriers?
    Sent from my iPhone using Tapatalk
  2. notenoughtime
    Essex
    280 carriers if your going 280mm discs
    256 carriers if 256mm etc
  3. sprout99
    sprout99 Paid Member Paid Member
    Durham
    although the pads have same footprint there is a difference in pad material thickness
    I recall on my 16v... i had 256mm callipers on 280mm carriers
    and i had to modifiy the slide pins
    i may have had wrong pins but where you stick the 15mm spanner had to be shortened by about 2mm
    its a nice mod and will fill the 15" wheels.....BTW. be carefull of offset on some 15" wheels
  4. L33mox
    Ok thanks for the info [emoji106]
  5. sprout99
    Durham
    G60 callipers are bulkier than the 256mm
  6. Jon Olds Forum Junkie
    The hubs have a wider bolt centre two, where the caliper carrier bolts on, so go for the whole set-up
    Unless I'm mistaken
    Jon
  7. rubjonny
    if you use 256mm discs then the 280 calipers will fit 16v 256mm carriers no problem, just they are a bit wider to suit the thicker 280mm disc and pad combo. This can give you wheel clearance issues depending on what you plan to fit, I'm sure there will be plenty guys out there who will be happy to swap their 256mm carriers for your 280s :)
  8. L33mox
    Thanks for the replys , mite just stay with 256 set up, it's only because my callipers are are shot, I understand mk3 256 callipers and carriers fit or 280mm ?
  9. rubjonny
    yeah some of the mk3s have the same 256mm vented brakes as the mk2 16v, but watch out some of them have solid 256mm discs which are no use as the calipers are not wide enough
  10. L33mox
    [emoji106] will make sure I get the right ones
