How to fit front big bumper guides?
Discussion in 'Mk2' started by trmorgan95, Sep 23, 2017.
  1. trmorgan95 New Member
    Hi guys, one of the plastic guides on the side of my big bumper has broke and is sagging badly, when I took the bumper of it appears the guides aren't bolted on but 'melted on' if that makes sense, what's the best way to remove and refit a new guide?
    Link to a few pics here: https://m.imgur.com/gallery/aKTfJ
    what ive done in the past is carefully drill/chop/chisel off the head of the melted studs, then used a suitable self tapper to secure the new bracket :)
  3. dsj20v Forum Member
    sunny hampshire
    Use a small blowtorch heat the flattened plastic tabs then slide off slider, get tabs hot again and twist into a point as such, couple of minutes to cool down, slide new slider over 4 tabs then reheat and squash tabs back down , let it cool down and away u go
