rear anti rollbar
Discussion in 'Mk2' started by joels, Nov 21, 2017.
  1. joels New Member
    im doing few mods to my golf any pros or cons to add rear antiroll bar.
    my beam is gti one so has the standed one
  2. 8bitAl Forum Member
    You'll get more lift off oversteer, this can be a pro or a con depending on the environment your driving the car in and driver skill.
    Alex.
  3. sports racer Forum Member
    Australia
    Go for it. You'll need one at least 22mm thick. It's not until you start going over 26mm thick that you start getting lift off oversteer and even then it's very handy having a car that tightens into a corner if it catches you out and you have to brake mid corner.
    Polybush the front antiroll bar, that's all it needs as the front bar doesn't make as much difference as a rear one so no need to waste money on a thicker one.
    If you were racing the car it would be a different story.
    What other suspension mods have you done?
    Paul
  4. 8bitAl Forum Member
    I can get lift of oversteer on my stock gti if I get silly.
  5. sports racer Forum Member
    Australia
    And I bet you know how to control it. :thumbup:
