Results 1 to 17 of 17
Thread: My winter 1800 ev rebuild project
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    Default My winter 1800 ev rebuild project
    Started rebuilding this a few weeks ago as I think my 1600 eg has lost a few horses over its life
    And only put it in to get the car on the road initially.Click image for larger version.
ID:	6284ev block stripped
    Down and covered in gunge.
    Some parts orderedClick image for larger version.
    Painted block and put in new mainsClick image for larger version.
    Cleaned up Pistons Click image for larger version.
    Tried a new compression ring in the bore with an old ring next to it.
    Old ring gap was .79mm new ring is .012Click image for larger version.
    Bores were honed as one of the first jobs but didn't get a pic.
    Pistons are going inClick image for larger version.
    New crank sealsClick image for larger version.
    New intermediate sealClick image for larger version.
    This is as far as I've got for now but not much more to do on bottom endClick image for larger version.
  2. The Following 2 Users Say Thank You to mk2 nas For This Useful Post:
  3. #2
    Moderator notenoughtime's Avatar
    Jan 2014
    Essex
    3,340
    684
  4. #3
    Moderator
    Nov 2012
    768
    132
    Looks good. I really want to strip an engine. I think I might buy another 20v and build it for big power, that'd be a nice learning curve.
  5. #4
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    This is my first engine rebuild
    So double/triple checking everything.and if I'm not sure I will just post on this thread
    As there's advice( by the bucket load )and very useful.
    I'm sure there's going to be some challenges when it comes to doing the head.
    Although not planning to much with it..but stem seals are a must while it's apart.
    Although you never know a cheapish cam might come up for sale
  6. #5
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    Gonna change this pulley also,it dosnt seem too bad but there's a small corner of key way missing/damaged.Click image for larger version.
    Not worth not doing for the sake of 15-20 quid.
    But I think I may need a new bolt also and can't seem to find one,anybody know where to source the bolt for the crank/pulley.
  7. #6
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    New crank gear pulley and bolt fitted today.(damn that bolt is sooo tight)
    Oil pump inspected for wear seems good and well within wear limits on integral cogs etc.
    Oil strainer has been completely cleared of any crud.so I will re-use it.Click image for larger version.
ID:	6502Click image for larger version.
ID:	6503Click image for larger version.
  8. #7
    Paid Member
    Jan 2004
    3,495
    61
    Good stuff, keep it coming, love an EG.
    I have a race spec one, in a race spec mk1, and a complete original engine/gearbox/injection mk1 unit needing oversized pistons (poor bores) (anybody?)
    Jon
  9. The Following User Says Thank You to Jon Olds For This Useful Post:
  10. #8
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    My 1600 eg is coming out in 2/3 weeks for this 1800 EV.
    I'm holding onto to the eg engine for a another future rebuild.dosnt hurt to have a couple of decent engines knocking about.
    Do you build up your own race spec units.
    I'm in the habit of doubling on car parts for my mk1 cabby.
    X2 engines x2 020 g/boxes, 3x k jet metering heads,and so on.
    I'm sure there's people on here that could open a small parts store.
  11. #9
    Forum User Marty's Dub's Avatar
    Aug 2006
    'Wexford on sea'
    847
    65
    Coming along nicely.
  12. #10
    Aug 2006
    'Wexford on sea'
    847
    65
    Quote Originally Posted by Jon Olds View Post
    Jon
    No idea Jon! Might be worth an enquiry. I am in way over my head here though. https://www.ebay.ca/itm/Audi-Fox-VW-...pTaYZY&vxp=mtr
  13. #11
    Paid Member Finite's Avatar
    Nov 2004
    Northamptonshire
    1,932
    141
    That should give the cab a bit of extra pep when it's all done . I have plans similar to yours, but the rebuild will hopefully be on the old engine first (particularly as I have no where to do it at present). I've never tackled it before either so I'm watching with interest.
    It's worth sorting the original engine in case you need it for road tax exemption which is 4ish? years away now.
    1989 5dr MK II 8v Helios Blue Bodyguards® 4 Nitrile Edition. 21 years of ownage.
  14. #12
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    Finite,as you know I'm a stones throw from you if you need any help etc.let me know.
    I'm hoping the cab feels quicker,I'm thinking of a nice exhaust too that makes a good sound
    But not too silly.what does anyone recommend.
  15. The Following User Says Thank You to mk2 nas For This Useful Post:
  16. #13
    Nov 2004
    Northamptonshire
    1,932
    141
    Have you got anything to lift the engine out with? Since I've got a bad back now as the song goes "machines will do the heavy work" I may buy a crane even if I sell it on afterwards.
  17. #14
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    I hire the engine lift in town for I think 15 quid a day.i would buy one but can't be bothered trying to store one as
    My storage is rammed.i don't mind hire.if your gonna be ready near mid Feb to pull your engine we could do both in one
    Day (if you want) it's easier with 2.although I have took em out and in on my own.
    A few years back I removed head lowered block and g/box to floor jacked up car and dragged
    It out with a rope caveman style.
    But don't do things like that now as like you my back would give up.
  18. #15
    Nov 2004
    Northamptonshire
    1,932
    141
    That doesn't sound too bad do they come with the bar with two chains? I think it would be a bit of a struggle without that. It might be a bit too soon for me. I'm thinking about trying to get an MOT on it with the oil pressure switches swapped around as John suggested just to get it through. The rear beam bushes want doing and the front wishbones
    That's it I have a painful ongoing reminder that it's more risky as you age and any short term gain from over exertion is outweighed by loss of earnings.
  19. #16
    Paid Member
    Jul 2013
    Northamptonshire
    627
    80
    I don't know what issues your having with your mk2,I think I recall
    Something was wrong last year.has it been off road long.
  20. #17
    Nov 2004
    Northamptonshire
    1,932
    141
    Quote Originally Posted by mk2 nas View Post
    It's almost 10 months now. Low oil pressure in the head. I'm fairly certain the bottom end is fine, but the head is certain to need work if its salvageable. It will no doubt need a skim as its intermittently boiled over for years.
