Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: Sticky tyres
    Forum User
    Oct 2016
    Laurencekirk, Aberdeenshire
    31
    Default Sticky tyres
    I'm looking for advice on tyres that will be super grippy 195/45/15
    The mk2 will run an abf. And be used mainly for back roads.
    Road noise isn't a problem, neither is how long they last either really as it'll be a weekend toy.
    I usually use Toyo proxes t1r but want others options before I go with them again.
    Moderator notenoughtime's Avatar
    Jan 2014
    Essex
    3,340
    684
    Why the low profile? back roads tend to have bumps/dips holes etc why not go up a size as you may find it less Harsh
  3. #3
    Forum User
    Oct 2016
    31
    That was the size in the proxes I found suited best to my driving style at the time.
    Granted the new setup will have better suspension etc so I could probably get away with bigger profiles, I'm open to any suggestions really.
  4. #4
    Administrator
    Oct 2003
    Bristol
    15,392
    450
    A few I have used are federal 595’s which are good but they are quite wide, a 195 is more like a 205. Also rainsport 1’s but there is a rainsport 2 now which everyone raves about.
    Without going down the road legal track tyre route (R888) it depends on how far you want to go and spend!
  5. The Following User Says Thank You to mat-mk3 For This Useful Post:
  6. #5
    Paid Member
    Aug 2014
    109
    I was going to recommend Nankang NS2R but they don't so them in that size. It's not a very common size so limits selection . A 195/50/15 gives you a lot more choice.
    But that tyre is 3.7% bigger so around 20mm larger in diameter than the 195/45/15 .
    https://www.tyreleader.co.uk/car-tyr...r15-86w-450711
  7. The Following User Says Thank You to Desertstorm For This Useful Post:
  8. #6
    Forum Junkie
    Apr 2006
    3,383
    141
    Have Nankang "come good"? Once upon a time they were regarded as Ditch finders, around here. I'm also looking for a sticky, back road usable 195 50 15 for my mk2 that will work wet or dry.
  9. #7
    Forum Junkie
    Apr 2006
    3,383
    141
    Quote Originally Posted by mat-mk3 View Post
    I think there's actually a Rainsport 3 now.
  10. #8
    Moderator
    Nov 2012
    768
    132
    Quote Originally Posted by Tristan View Post
    Yep. I've got RS3's on my mk2. This is my second set now. They're fantastic.
  11. #9
    Forum Junkie
    Apr 2006
    3,383
    141
    Good on hot dry days, Sam?
  12. #10
    Jul 2006
    16,365
    3,003
    Mk2 road tyres IMO, I use Rainsport 3.
    On track, where it is safe this is what I observed.
    On a dry track were corner speeds are higher and braking can be later, depending on your cars suspension set up and bravery, you need tyres with increased grip and stiffer side walls. So R888 G, A048, Dirreza DZ03G and so on. Those result in a horrible ride as a road tyre!
    On a wet track, the flexible character of the Rainsport 3 side walls and the tyre blocks provide excellent confidence in standing water while on track.
    On a road, you could never drive the same on a track, so optimum performance for tyres on a track is never exercised.
  13. #11
    Forum Junkie copeidge's Avatar
    Dec 2007
    2,354
    The Nankangs you are thinking of are the Ns2's which are very cheap standard road tyres and from my own experience found them okay on the road.
    The Nankangs that have been mentioned above are NS-2R which are a semi slick. I use them on my mk2 in a 195/50 profile and they are fantastic!! super grippy in the dry and have a B rating in the wet. I've now done 4 track days, 3 trips to the 'Ring and road miles and they still have 2mm left.
    Picture below is after 1 lap of the Ring
    Nankang have also brought out an AR-1 which I'll try next, these wont be as good in the wet but they are their equivalent of an R888.
    All in all I cant rate the NS-2R enough! for £60 corner I dont think they can be beaten.
  14. #12
    Paid Member Finite's Avatar
    Nov 2004
    Northamptonshire
    1,932
    141
    I found RS3 progressively turn to jelly with increasing under steer/soft shoulder from warm+sunny conditions, but on the other hand they are ridiculously good in the wet and don't suffer badly like summer tyres (15" limitations) when it's damp and cold.
    I haven't run a full set, only fronts which perhaps makes it more noticeable. At Curby I swapped them to the back bringing old rear summer tyres (Eagle F1) to the front as the track temperature rose significantly.
    I guess wide track helps to a degree, but I don't know how Sam set such good times on them really on the same day.
    1989 5dr MK II 8v Helios Blue Bodyguards® 4 Nitrile Edition. 21 years of ownage.
  15. #13
    Administrator
    Oct 2003
    Bristol
    15,392
    450
    Christ, a rainsport 3! As i say, a lot of people with high power MK5 GTI's run them.
    I'm running Pilot Sport 3's on my MK6 GTI and they are amazing, grip in all weather but they don't go down to 15" sadly.
  16. #14
    Jul 2006
    16,365
    3,003
    Quote Originally Posted by Finite View Post
    On a dry track day, I never run Uniroyal RS3s. They just melt and try to bend under the car...
  17. #15
    Jul 2006
    16,365
    3,003
    Those are a some leap above cheapo RS3s I should add. Very good rubber for the road and track.
  18. #16
    Paid Member drunkenalan's Avatar
    Jun 2004
    Leicester
    6,496
    32
    195/50/15 Rainsports get my vote, I did a few days at Mallory on them never had any issue with them either on the road or with my road weight daily mk2 on the track.
    my only comment is would be, I did one track day on my OE steels and they seemed to roll a lot more than when on my 7j wider alloys, but I guess that's more to do with the wheel than the tyre.
    1985 MK2 GTI - 1900 TSR 8v engine 158bhp..
    2001 Oettinger Bora http://www.clubgti.com/forum/showthread.php?t=251790 Becoming a V6 very soon
  19. #17
    Forum Junkie
    Apr 2006
    3,383
    141
    I always reckon tyres are cheaper than accidents. If you had to pick a single type of tyre to put on your mk2, to drive to the Ring, and lap it, drive home and go to work on, and not sure if it was going to be wet or dry, what would you choose?
  20. #18
    Jul 2006
    16,365
    3,003
    Federal 595 tyres.
  21. #19
    Forum Junkie
    Apr 2006
    3,383
    141
    Oh yeah? Why so, Ed?
  22. #20
    Jul 2006
    16,365
    3,003
    Ok all round tyre.
    Not very noisy into the cabin so pleasant over long distance.
    Enough grip and sidewall stiffness for a few enthusiastic laps of the ring.
    Okay in the damp/wet.
    Sort of midway tyre between full road and full track. Had them on my old MK3 VR6.
  23. #21
    Forum Junkie beetie's Avatar
    Dec 2003
    leicester
    2,457
    578
    Rainsport 3 on the back of my mk5 was horrible as the sidewalls are so soft. Always felt as though the rear was unstable/sliding. I quickly moved them to the front.
    They are a lot heavier than a mk2 though
  24. #22
    Forum Junkie
    Nov 2003
    Abz
    5,346
    1,104
    pp Toyotec ... Dunlop Dirreza DZ03G, based on my experience of it`s predecessor the DOIJ.
  25. #23
    Moderator
    Nov 2012
    768
    132
    I'll be trying a set of NS2R's in the summer. See how they fare..
    But for wet driving, 90% of the time in the UK, then the Rainsports are perfect. They held up surprisingly well at Curby, I was surprised.
  26. #24
    Forum User
    Oct 2016
    31
    So it looks like Rainsport 3s or NS-2R seem to be the ones of choice.
    I'm running KW V2, all pollybushed etc, and the car will only really be used on "nice" days, never as a daily. and the car will never see salt or snow. so out of those two options what would people suggest?
  27. #25
    Forum Junkie
    Nov 2003
    Abz
    5,346
    1,104
    NS-2R ... see you on the Hill of Garvock and Cairn O`Mount then
