Results 1 to 6 of 6
Thread: Golf MK1 Oil Dip Stick Shroud
    Forum User
    Mar 2011
    40
    Default Golf MK1 Oil Dip Stick Shroud
    Hi guys,
    Probably not standard part for my DX engine as it’s in a camper van conversion but this has perished and I think letting in in metered air:
    The bottom part around the tube has broken apart. Anyone know where to source or a part number?
    Forum User
    Jan 2013
    Trowbridge
    273
    I think they are available at vw heritage and now orange you might get them via a dealers still as well
  3. #3
    Forum User Marty's Dub's Avatar
    Aug 2006
    'Wexford on sea'
    847
    65
  4. #4
    Forum User
    Mar 2011
    40
    Will that fit the metal style handle dipstick I have?
    Most of the ones I have seen online for the Mk1 / Mk2 are plastic handle and seem to have a different insert for the guide?
  5. #5
    Aug 2006
    'Wexford on sea'
    847
    65
    Probably won't no. My Bad. Well after some digging, I found this https://vwgolfmk1.org.uk/forum/index...ssues&start=20 which then got me searching. https://volkswagen.7zap.com/en/rdw/g...-7/1/103-3000/ If you trawl through it you'll find a few numbers Item#44 looks to be the part you're after, although I was convinced it was. The part diagram lists the DX as having Part No. 053 103 663, Item#39.They are both available. https://www.vwheritage.com/036115636...10-17-vw-spare . After looking at this, I could still well be wrong. I do apologise.
  6. #6
    Moderator rubjonny's Avatar
    Oct 2003
    41,908
    188
    Your engien block is later type which needs the plastic guide tube, the early tube didnt have a plastic end.
    issue you have though is which dipstick and/or guide tube you need for a van, since I think the engine sits leaned over a bit more? If so then the oem golf tube/guide/dipstick probably isnt going to work correctly to suit the level the oil will be sat at when engine is installed in a van
    VAG Documents & Downloads
